andy_06 Posted 13 hours ago Posted 13 hours ago Hi, I am looking for some help with regards to a lisp routine. I have a scenario where I need to select multiple blocks (all named 'Service Connection') and then explode them. I currently do this using Qselect and then manually explode but wonder there is a way to do all of this in one lisp routine to speed up the process? Thank you! Quote
GLAVCVS Posted 9 hours ago Posted 9 hours ago Try this (defun c:myExplode (/ conj n ent lstent nmBlq para) (while (not para) (if (setq ent (car (entsel "\nSelect a sample of blocks to explode..."))) (if (= (cdr (assoc 0 (setq lstent (entget ent)))) "INSERT") (setq nmBlq (cdr (assoc 2 lstent)) para T ) (princ "\n*** SELECTED OBJECT IS NOT A BLOCK ***\Please, try again..." ) ) (princ "\n*** NOTHING SELECTED ***\Please, try again..." ) ) ) (setq n 0) (if nmBlq (if (setq conj (ssget "x" (list (cons 0 "INSERT") (cons 2 nmBlq)))) (WHILE (SETQ ent (SSNAME conj n)) (setq lstent (entget ent) n (+ n 1) ) (vla-explode (vlax-ename->vla-object ent)) ) ) ) (princ) ) Quote
andy_06 Posted 9 hours ago Author Posted 9 hours ago 13 minutes ago, GLAVCVS said: Try this (defun c:myExplode (/ conj n ent lstent nmBlq para) (while (not para) (if (setq ent (car (entsel "\nSelect a sample of blocks to explode..."))) (if (= (cdr (assoc 0 (setq lstent (entget ent)))) "INSERT") (setq nmBlq (cdr (assoc 2 lstent)) para T ) (princ "\n*** SELECTED OBJECT IS NOT A BLOCK ***\Please, try again..." ) ) (princ "\n*** NOTHING SELECTED ***\Please, try again..." ) ) ) (setq n 0) (if nmBlq (if (setq conj (ssget "x" (list (cons 0 "INSERT") (cons 2 nmBlq)))) (WHILE (SETQ ent (SSNAME conj n)) (setq lstent (entget ent) n (+ n 1) ) (vla-explode (vlax-ename->vla-object ent)) ) ) ) (princ) ) That is perfect, thank you so much! Quote
andy_06 Posted 8 hours ago Author Posted 8 hours ago I have been testing this and it works great for a standard block but I also have a scenario where I have some dynamic blocks and it doesn't seem to work for those. Is there a way to include dynamic blocks as well? Quote
LanloyLisp Posted 5 hours ago Posted 5 hours ago (defun c:myExplode (/ conj n ent lstent nmBlq para) (while (not para) (if (setq ent (car (entsel "\nSelect a sample of blocks to explode..."))) (if (= (cdr (assoc 0 (setq lstent (entget ent)))) "INSERT") (setq v (vlax-ename->vla-object ent) ;; nmBlq (cdr (assoc 2 lstent)) nmBlq (vla-get-effectivename v) para T ) (princ "\n*** SELECTED OBJECT IS NOT A BLOCK ***\Please, try again..." ) ) (princ "\n*** NOTHING SELECTED ***\Please, try again..." ) ) )(print (strcat nmBlq ",`*U*")) (setq n 0) (if nmBlq (if (setq conj (ssget "x" (list (cons 0 "INSERT") (cons 2 (strcat nmBlq ",`*U*"))))) (WHILE (SETQ ent (SSNAME conj n)) (setq v (vlax-ename->vla-object ent) lstent (entget ent) n (+ n 1) ) (if (eq (vla-get-effectivename v) nmBlq) (vla-explode v) ) ) ) ) (princ) ) Hi Andy, check the above code, few edits from GLAV's original code. Quote
Lee Mac Posted 4 hours ago Posted 4 hours ago Note that (vla-explode) creates an exploded copy, the original reference will still exist. Quote
