To enable multileader blocks, you'll need to change the objtype parameter to 3 (= 1+2).
oops.
How did you make it auto update if you copied/paste the multi leader? now the mleader updates but it doesn't seem to do it if i just copy and paste. I tried the Copy command and ctrl+c, neither seem to work.
Edited by neuri
Are you maybe cancelling the COPY command with ESC rather than allowing it to terminate properly?
Oh.. so i need to Exit instead of using Esc.
I have a habit of using Esc, thanks for the help!
Esc cancels a command and so from the perspective of the reactor, the command has been cancelled or has failed.
