neuri Posted Tuesday at 08:20 AM Posted Tuesday at 08:20 AM I finally got it to work with Blocks, as in, when I insert a Block, the number updates automatically. But when used in a multileader, it doesn't work. If I copy and paste, it doesn't update either. Can someone advise me on what I am doing wrong? auto label test.dwg Autolabel.lsp Quote
Lee Mac Posted Tuesday at 11:35 PM Posted Tuesday at 11:35 PM To enable multileader blocks, you'll need to change the objtype parameter to 3 (= 1+2). Quote
neuri Posted Wednesday at 04:55 PM Author Posted Wednesday at 04:55 PM (edited) oops. How did you make it auto update if you copied/paste the multi leader? now the mleader updates but it doesn't seem to do it if i just copy and paste. I tried the Copy command and ctrl+c, neither seem to work. Edited Wednesday at 04:56 PM by neuri Quote
Lee Mac Posted Wednesday at 05:58 PM Posted Wednesday at 05:58 PM Are you maybe cancelling the COPY command with ESC rather than allowing it to terminate properly? 1 Quote
neuri Posted Thursday at 01:46 AM Author Posted Thursday at 01:46 AM Oh.. so i need to Exit instead of using Esc. I have a habit of using Esc, thanks for the help! Quote
Lee Mac Posted Thursday at 08:48 AM Posted Thursday at 08:48 AM Esc cancels a command and so from the perspective of the reactor, the command has been cancelled or has failed. 1 Quote
