INZENJERIJA Posted January 12 Posted January 12 Hello people, I have a problem with certain lisp routines in AutoCAD Map 3D 2022, they just suddenly stopped working, or rather they reach a certain part of the code and throw the error "Error: no function definition: VLAX-ENAME-> VLA-OBJECT". Searching the forums, I came across solutions such as changing the REGISTRY, completely uninstalling the application, but I can't seem to overcome this problem, please help. Greetings to all Quote
BIGAL Posted January 12 Posted January 12 (edited) Welcome aboard. Try adding (vl-load-com) at start of code. If that does not work can you post code here ? Edited January 12 by BIGAL 1 Quote
INZENJERIJA Posted January 13 Author Posted January 13 regards @BIGAL, first of all, thanks for reporting, the last time I uninstalled acad, it wouldn't install version 2022, which was the problem, I switched to version 2019, where it's working fine for now. Searching the forums, I came across the same suggested solution as yours, but that didn't work either. I have some patches that work on version 2022, but I have to give up on that version because it really bothered me, I'll post my new problem to see if anyone else has had a similar situation or should I open a new topic? Thank you again @BIGAL, Quote
SLW210 Posted January 13 Posted January 13 Did you try a complete uninstall and reinstall? How to perform a Clean Uninstall of Autodesk products on Windows Did you try these solutions? "Error: no function definition: VLAX-ENAME->VLA-OBJECT" when running LISP based function in AutoCAD Quote
INZENJERIJA Posted January 13 Author Posted January 13 Yes, I came across this solution too, but it didn't help either, now my priority is to install Acad Map 3D 2022 in general. Quote
tombu Posted January 14 Posted January 14 On 1/13/2025 at 9:29 PM, INZENJERIJA said: Yes, I came across this solution too, but it didn't help either, now my priority is to install Acad Map 3D 2022 in general. Expand If you have the license why not install the current 2025 version? Is the 2022 version still available online? Quote
INZENJERIJA Posted January 20 Author Posted January 20 the same problem came back again with the message VLAX-ENAME-> VLA-OBJECT, this still looks like the system should be working, I tried the new version of acad but to no avail Quote
BIGAL Posted January 21 Posted January 21 It is the policy of many people here that we can not support the use of cracked versions. Admin may intervene. Quote
SLW210 Posted January 21 Posted January 21 Such is the problem with cracked programs, they are not worth the price you paid. 1 Quote
