Hello people,
I have a problem with certain lisp routines in AutoCAD Map 3D 2022, they just suddenly stopped working, or rather they reach a certain part of the code and throw the error "Error: no function definition: VLAX-ENAME-> VLA-OBJECT". Searching the forums, I came across solutions such as changing the REGISTRY, completely uninstalling the application, but I can't seem to overcome this problem, please help. Greetings to all
Welcome aboard.
Try adding (vl-load-com) at start of code.
If that does not work can you post code here ?
Edited by BIGAL
