Mystogan Posted Friday at 06:54 PM Posted Friday at 06:54 PM Hi everyone, Thank you for taking the time to visit. I hope you can assist me with my current challenge. I came across Lee Mac's LSP script, which seems very promising and helpful. I’m hoping someone can help modify Lee Mac's code to update the entire list of DWG files in the drawing column of a CSV file. Here’s the code of UpdateTitleblockV1-9.lsp ;;-----------------------=={ Update Attributes }==----------------------;; ;; ;; ;; Reads a CSV file containing attribute data, and, should the drawing ;; ;; name of the current drawing appear in the first column of the CSV ;; ;; Drawing List, the program will proceed to update block attributes. ;; ;; ;; ;; The attributes updated will be those with tags corresponding to the ;; ;; CSV column headings. These will be updated with values from the ;; ;; row in which the drawing file is listed. ;; ;; ;; ;; ------------------------------------- ;; ;; Example of CSV format: ;; ;; ------------------------------------- ;; ;; ;; ;; +------------+-----------+-----------+----------+-----+----------+ ;; ;; | DWG | Layout* | Block* | TAG1 | ... | TAGN | ;; ;; +------------+-----------+-----------+----------+-----+----------+ ;; ;; | Drawing1 | Layout1 | Block1 | Value1 | ... | ValueN | ;; ;; +------------+-----------+-----------+----------+-----+----------+ ;; ;; | Drawing1 | Layout2 | Block1 | Value1 | ... | ValueN | ;; ;; +------------+-----------+-----------+----------+-----+----------+ ;; ;; | Drawing2 | Layout1 | Block2 | Value1 | ... | ValueN | ;; ;; +------------+-----------+-----------+----------+-----+----------+ ;; ;; | ... | ... | ... | ... | ... | ... | ;; ;; +------------+-----------+-----------+----------+-----+----------+ ;; ;; ;; ;; *Layout & Block Name columns are optional. ;; ;; ;; ;; ------------------------------------- ;; ;; Possible Warnings: ;; ;; ------------------------------------- ;; ;; - Without a block filter or block name column the code will ;; ;; update ALL attributed blocks with tags listed in the CSV ;; ;; headings. ;; ;; ;; ;; - Currently designed to run on startup - add to either ;; ;; Startup-Suite or ACADDOC.lsp to update blocks when drawing is ;; ;; opened. To disable code running when loaded, remove (c:utb) ;; ;; from the bottom of the code. ;; ;; ;; ;;----------------------------------------------------------------------;; ;; Author: Lee Mac, Copyright 2011 - www.lee-mac.com ;; ;;----------------------------------------------------------------------;; ;; Version 1.0 - 2011-01-12 ;; ;; ;; ;; - First release. ;; ;;----------------------------------------------------------------------;; ;; Version 1.1 - 2011-01-13 ;; ;; ;; ;; - Added optional 'Layout' column (next to DWG Column) to allow ;; ;; multiple titleblocks to be updated with different information ;; ;; within a single drawing. ;; ;;----------------------------------------------------------------------;; ;; Version 1.2 - 2011-08-28 ;; ;; ;; ;; - Removed case-sensitivity of drawing file column in CSV. ;; ;;----------------------------------------------------------------------;; ;; Version 1.3 - 2011-12-27 ;; ;; ;; ;; - Revised the code to correctly process CSV files generated using ;; ;; OpenOffice software. ;; ;;----------------------------------------------------------------------;; ;; Version 1.4 - 2012-01-16 ;; ;; ;; ;; - Updated the 'ReadCSV' local function to correctly read CSV cells ;; ;; containing commas and quotes. ;; ;;----------------------------------------------------------------------;; ;; Version 1.5 - 2012-09-19 ;; ;; ;; ;; - Updated CSV file parser function to account for the use of ;; ;; alternative cell delimiter characters in CSV file (such as a ;; ;; semi-colon). ;; ;;----------------------------------------------------------------------;; ;; Version 1.6 - 2013-05-22 ;; ;; ;; ;; - Removed the need for file extension in first column of CSV file. ;; ;; - Updated CSV file parser function to correct bug. ;; ;;----------------------------------------------------------------------;; ;; Version 1.7 - 2014-11-01 ;; ;; ;; ;; - Fixed bug causing filenames containing ASCII character 46 (point) ;; ;; to not be found in the first column of the CSV file. ;; ;;----------------------------------------------------------------------;; ;; Version 1.8 - 2015-04-13 ;; ;; ;; ;; - Added support for duplicate attribute tags. ;; ;; - Added support for optional 'Block Name' column in CSV file. ;; ;; - Added inclusion of anonymous block names to optional block name ;; ;; filter to enable dynamic block support. ;; ;;----------------------------------------------------------------------;; ;; Version 1.9 - 2016-09-18 ;; ;; ;; ;; - Fixed implementation of block filter when processing attributed ;; ;; dynamic blocks. ;; ;;----------------------------------------------------------------------;; (defun c:utb ( / *error* ano bln bno csv ent flg fnb:fun inc lst sel str tag utb:blk utb:csv utb:ftr utb:lay val ) ;;----------------------------------------------------------------------;; ;; Location of CSV Drawing List (set to nil for prompt) ;; ;; ;; ;; If the CSV file resides in the same directory as the drawing, omit ;; ;; the filepath from the location of the CSV file, and only include ;; ;; the filename, e.g. "myfile.csv" ;; ;; ;; ;; If only a filename is specified, AutoCAD will first search the ;; ;; working directory for this file before searching the Support Paths. ;; ;;----------------------------------------------------------------------;; (setq utb:csv nil) ;; e.g. (setq utb:csv "C:/myfolder/myfile.csv") ;;----------------------------------------------------------------------;; ;; Block Filter (may use wildcards and may be nil) ;; ;;----------------------------------------------------------------------;; (setq utb:ftr nil) ;; e.g. (setq utb:ftr "*BORDER") ;;----------------------------------------------------------------------;; ;; Layout Column (t or nil) ;; ;;----------------------------------------------------------------------;; (setq utb:lay t) ;; set to t if CSV file contains Layout Column ;;----------------------------------------------------------------------;; ;; Block Name Column (t or nil) ;; ;;----------------------------------------------------------------------;; (setq utb:blk nil) ;; set to t if CSV file contains Block Name Column ;;----------------------------------------------------------------------;; (defun *error* ( msg ) (LM:endundo (LM:acdoc)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (setq fnb:fun (lambda ( s ) (if (wcmatch (strcase s t) "*.dwg,*.dxf,*.dwt,*.dws") (vl-filename-base s) s ) ) ) (cond ( (not (setq sel (ssget "_X" (vl-list* '(0 . "INSERT") '(66 . 1) (if utb:ftr (list (cons 2 (strcat "`*U*," utb:ftr)))))))) (princ "\nNo Attributed Blocks found in drawing.") ) ( (and utb:csv (not (setq csv (findfile utb:csv)))) (princ (strcat "\n" (vl-filename-base utb:csv) (vl-filename-extension utb:csv) " not found." ) ) ) ( (and csv (/= ".CSV" (strcase (vl-filename-extension csv)))) (princ "\nAttribute data file must be in CSV format.") ) ( (not (or csv (setq csv (getfiled "Select CSV File" "" "csv" 16)))) (princ "\n*Cancel*") ) ( (not (setq lst (mapcar '(lambda ( x ) (cons (strcase (fnb:fun (car x))) (cdr x))) (LM:readcsv csv)))) (princ (strcat "\nNo data found in " (vl-filename-base csv) ".csv file." ) ) ) ( (not (setq tag (mapcar 'strcase (cdar lst)) lst (LM:massoc (strcase (fnb:fun (getvar 'dwgname))) lst) ) ) (princ (strcat "\n" (fnb:fun (getvar 'dwgname)) " not found in first column of CSV file.")) ) ( t (setq lst (mapcar '(lambda ( x ) (mapcar 'cons tag x)) lst) ano 0 bno 0 ) (LM:startundo (LM:acdoc)) (repeat (setq inc (sslength sel)) (setq ent (ssname sel (setq inc (1- inc))) bln (strcase (LM:al-effectivename ent)) val lst flg nil ) (if (or (null utb:ftr) (wcmatch bln (strcase utb:ftr))) (progn (if utb:lay (setq val (mapcar '(lambda ( x ) (cons (strcase (cdar x)) (cdr x))) val) val (LM:massoc (strcase (cdr (assoc 410 (entget ent)))) val) ) ) (if utb:blk (setq val (mapcar '(lambda ( x ) (cons (strcase (cdar x)) (cdr x))) val) val (cdr (assoc bln val)) ) (setq val (car val)) ) (if val (foreach att (vlax-invoke (vlax-ename->vla-object ent) 'getattributes) (if (and (setq str (assoc (strcase (vla-get-tagstring att)) val)) (progn (setq val (LM:remove1st str val)) (/= (vla-get-textstring att) (cdr str)) ) ) (progn (vla-put-textstring att (cdr str)) (setq flg t ano (1+ ano) ) ) ) ) ) (if flg (setq bno (1+ bno))) ) ) ) (if (zerop ano) (princ "\nAll attributes are up-to-date.") (princ (strcat "\n" (itoa ano) " attribute" (if (= 1 ano) "" "s") " updated in " (itoa bno) " block" (if (= 1 bno) "" "s") "." ) ) ) (LM:endundo (LM:acdoc)) ) ) (princ) ) ;; Effective Block Name - Lee Mac ;; ent - [ent] Block Reference entity (defun LM:al-effectivename ( ent / blk rep ) (if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) "`**") (if (and (setq rep (cdadr (assoc -3 (entget (cdr (assoc 330 (entget (tblobjname "block" blk) ) ) ) '("AcDbBlockRepBTag") ) ) ) ) (setq rep (handent (cdr (assoc 1005 rep)))) ) (setq blk (cdr (assoc 2 (entget rep)))) ) ) blk ) ;; Read CSV - Lee Mac ;; Parses a CSV file into a matrix list of cell values. ;; csv - [str] filename of CSV file to read (defun LM:readcsv ( csv / des lst sep str ) (if (setq des (open csv "r")) (progn (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (","))) (while (setq str (read-line des)) (setq lst (cons (LM:csv->lst str sep 0) lst)) ) (close des) ) ) (reverse lst) ) ;; CSV -> List - Lee Mac ;; Parses a line from a CSV file into a list of cell values. ;; str - [str] string read from CSV file ;; sep - [str] CSV separator token ;; pos - [int] initial position index (always zero) (defun LM:csv->lst ( str sep pos / s ) (cond ( (not (setq pos (vl-string-search sep str pos))) (if (wcmatch str "\"*\"") (list (LM:csv-replacequotes (substr str 2 (- (strlen str) 2)))) (list str) ) ) ( (or (wcmatch (setq s (substr str 1 pos)) "\"*[~\"]") (and (wcmatch s "~*[~\"]*") (= 1 (logand 1 pos))) ) (LM:csv->lst str sep (+ pos 2)) ) ( (wcmatch s "\"*\"") (cons (LM:csv-replacequotes (substr str 2 (- pos 2))) (LM:csv->lst (substr str (+ pos 2)) sep 0) ) ) ( (cons s (LM:csv->lst (substr str (+ pos 2)) sep 0))) ) ) (defun LM:csv-replacequotes ( str / pos ) (setq pos 0) (while (setq pos (vl-string-search "\"\"" str pos)) (setq str (vl-string-subst "\"" "\"\"" str pos) pos (1+ pos) ) ) str ) ;; MAssoc - Lee Mac ;; Returns all associations of a key in an association list (defun LM:massoc ( key lst / item ) (if (setq item (assoc key lst)) (cons (cdr item) (LM:massoc key (cdr (member item lst)))) ) ) ;; Remove 1st - Lee Mac ;; Removes the first occurrence of an item from a list (defun LM:remove1st ( itm lst / f ) (setq f equal) (vl-remove-if '(lambda ( a ) (if (f a itm) (setq f (lambda ( a b ) nil)))) lst) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc) ) ;;----------------------------------------------------------------------;; (vl-load-com) (princ (strcat "\n:: UpdateTitleblock.lsp | Version 1.9 | \\U+00A9 Lee Mac " (menucmd "m=$(edtime,0,yyyy)") " www.lee-mac.com ::" "\n:: Type \"utb\" to run manually ::\n" ) ) (princ) ;;----------------------------------------------------------------------;; ;;(c:utb) ;; Remove or comment this line to disable autorun ;;----------------------------------------------------------------------;; ;; End of File ;; ;;----------------------------------------------------------------------;; Quote
BIGAL Posted Friday at 11:08 PM Posted Friday at 11:08 PM Taking a step back, need to look at what is in your csv file, the processing may be the easy part. Is the CSV from Excel ? Post a sample Excel. Quote
Mystogan Posted Saturday at 12:41 PM Author Posted Saturday at 12:41 PM Hi Bigal, Yes, I’ve been using CSV from Excel with UTF-8 encoding. It seems to only work on the currently open drawing file. I’ve listed all the drawings in the same folder, but it doesn’t loop through all the drawing files as intended. I was wondering if you might have any ideas on how to revise this and make it loop through all the drawings stated in the CSV. I’d greatly appreciate your guidance! Thank you so much! Quote
Lee Mac Posted Saturday at 10:12 PM Posted Saturday at 10:12 PM You can loop through the drawings using a basic script: first, configure my program to run autonomously (so that the user is not prompted to specify a CSV file), and then use a script to open each drawing, run the program (or set it to run automatically on drawing startup), and then save and close the drawing. The script could even be created using my existing Script Writer program. Quote
BIGAL Posted Saturday at 10:35 PM Posted Saturday at 10:35 PM (edited) Hi Lee, would using OBDX work for unopened dwgs ? You can easily check what dwgs are already open and get their names. Maybe if more than one dwg open then ask to close all but one and start again. Then would not need a script. I don't use OBDX much but when I do, I use your code examples, thanks. Mystogan can you post a sample Excel. Edited Saturday at 10:36 PM by BIGAL Quote
Lee Mac Posted yesterday at 12:20 AM Posted yesterday at 12:20 AM ObjectDBX is feasible but comes with the usual known drawbacks such as attribute alignment issues for attributes without Left justification, the inability to control drawing file version (drawings are always saved to native format), loss of drawing thumbnails, etc. Quote
