Select Polylines (Right Direction) Of Block
@ronjonp
Telecom Network pipes
Just now, ronjonp said:
Glad to help .. if you don't mind what are these drawings used for?
9 minutes ago, Engineer_Yasser said:
@ronjonp
Nice! This should speed up your process considerably!
17 hours ago, ronjonp said:
@Saxlle IMO you should leave they layer filter out of the block: (ssget "X" '((0 . "INSERT") (2 . "blll")))
I'm put it because i didn't know what all is in the drawing (for e.g. multiple "blll" blocks in different layers, and to avoid selecting those which are not on polylines...), but after all, it is unnecessary for the selection filter. Thank you for suggestion 🥷. P.S. Your code was much better than my, concise and with a lot good skills.
Best regards.
  • Thanks 1
