Engineer_Yasser Posted January 9 Author Posted January 9 @ronjonp Telecom Network pipes On 1/9/2025 at 4:24 PM, ronjonp said: Glad to help .. if you don't mind what are these drawings used for? Expand Quote
ronjonp Posted January 9 Posted January 9 On 1/9/2025 at 4:26 PM, Engineer_Yasser said: @ronjonp Telecom Network pipes Expand Nice! This should speed up your process considerably! 1 Quote
Saxlle Posted January 10 Posted January 10 On 1/9/2025 at 3:25 PM, ronjonp said: @Saxlle IMO you should leave they layer filter out of the block: (ssget "X" '((0 . "INSERT") (2 . "blll"))) Expand I'm put it because i didn't know what all is in the drawing (for e.g. multiple "blll" blocks in different layers, and to avoid selecting those which are not on polylines...), but after all, it is unnecessary for the selection filter. Thank you for suggestion . P.S. Your code was much better than my, concise and with a lot good skills. Best regards. 1 1 Quote
Engineer_Yasser Posted January 10 Author Posted January 10 @Saxlle You did a great job also .. Nice work 1 Quote
