The problem with selecting initget "All/Select"
Hi, everybody. Happy New Year!
If I use these lines, the code works:
;(setq ss (ssget "_X" '((0 . "*TEXT"))) i -1) ; select all texts
(setq ss (ssget '((0 . "*TEXT"))) i -1) ; if you do not need to select the entire text
If I replace them with:
(initget "All Select")
 (setq select (getkword "\nSelect text to change [All/Select] <Select> : "))
 (if select
 (cond
 ( (= select "All") (setq SS (ssget "_X" '((0 . "MTEXT")))) )
 ( (= select "Select") (setq SS (ssget "_:L")) )
then the code doesn't work. Can you tell me how this can be fixed? Thank...
;; Create a new text style and replace all styles in the drawing
(defun c:cr-txtst-change ( / *error* ss eo i ff oldcmd acadDoc)
(vl-load-com)
 (defun *error* (msg)
  ) ;_ end defun
(setq acadApp (vlax-get-Acad-object))
(setq acadDoc (vla-get-ActiveDocument acadApp))
(setq styles (vla-get-textstyles acadDoc))
;; Add the style named "ArialN0"
(setq objStyle (vla-add styles "ArialN0"))
;; Assign fontfile "ARIALN.ttf" to the style
(setq ff "C:\\Program Files\\Autodesk\\AutoCAD 2019\\Fonts\\ARIALN.ttf")
(vla-put-fontfile objStyle ff)
;; Optional: Make the new style Active
(vla-put-activetextstyle acadDoc objStyle)
;(princ)
;; Replace all texts with the ArialN0 style
;; *************************** I'm trying to add a the possibility of choice ****************
;|	(initget "All Select")
 (if select
 (cond
 ( (= select "All") (setq SS (ssget "_X" '((0 . "*TEXT")))) )
(setq oldcmd (getvar "cmdecho")) (setvar "cmdecho" 0)
	(while (< (setq i (1+ i)) (sslength ss))
	(setq eo (vlax-ename->vla-object (ssname ss i)))
		(vlax-put eo 'StyleName "ArialN0")
(vla-EndUndoMark doc) ; Set the style to the current one
(vl-cmdf "_-PURGE" "_ST" " " "_N") ; clear unused text styles
(setvar "cmdecho" oldcmd)
Edited by Nikon
Just remove the asterisk when checking for equality.
(= select All)
(= select Select)
Edited by Tharwat
Typo
  • Thanks 1
(= select All)
(= select Select)
Expand
Thanks, but the code doesn't work, the style is created, but the texts style doesn't change...😉
It turns out that you need to change these lines:
to
( (= select "All") (setq SS (ssget "_X" '((0 . "*TEXT"))) i -1) )
 ( (= select "Select") (setq SS (ssget '((0 . "*TEXT"))) i -1) )
 (setq SS setq SS (ssget '((0 . "*TEXT"))) i -1)
so that they match the following lines:
Now the code works!
Here is the full code, if anyone is interested:
(defun c:cr-txtst-sel2 ( / *error* ss eo i ff oldcmd acadDoc)
(vl-load-com)
 ) ;_ end defun
;(princ)
;; Replace All/Select texts with the ArialN0 style
 (if select
 (cond
Edited by Nikon
@Nikon There were a few errors in the code you posted .. FWIW here are some modifications with comments.
(defun c:cr-txtst-sel2 ;; RJP - Localize all variables
		       (/ acaddoc eo ff i objstyle oldcmd select ss styles)
  (vl-load-com)
  ;; RJP - Check that the font can be found otherwise BOOM! Also search for the system font not tied to a CAD version
  (if (findfile (setq ff (strcat (getenv "WINDIR") "\\FONTS\\ARIALN.ttf")))
    ;; (findfile (setq ff "C:\\Program Files\\Autodesk\\AutoCAD 2019\\Fonts\\ARIALN.ttf"))
    (progn (setq acaddoc (vla-get-activedocument (vlax-get-acad-object)))
	   (setq styles (vla-get-textstyles acaddoc))
	   (setq objstyle (vla-add styles "ArialN0"))
	   (vla-put-fontfile objstyle ff)
	   (vla-put-activetextstyle acaddoc objstyle)
	   (if (= "All" (setq select (getkword "\nSelect text to change [All/Select] <Select> : ")))
	     (setq ss (ssget "_X" '((0 . "*TEXT"))))
	     (setq ss (ssget "_:L" '((0 . "*TEXT"))))
	   ;; RJP - Check for valid selection
	   (if ss
	     (progn (setq oldcmd (getvar "cmdecho"))
		      (setq eo (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
		      ;; RJP - Check that the text can be modified
		      (if (vlax-write-enabled-p eo)
			(vlax-put eo 'stylename "ArialN0")
		    ;; RJP - This line below bombs the code?
		    ;; (vla-endundomark doc) ; Set the style to the current one
    (alert (strcat ff " NOT FOUND!"))
Edited by ronjonp
Missed setting a variable
  • Like 2
I don't use initget anymore rather this.
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(setq ans (ah:butts but "V" '("Please Choose" "All" "All in tab" "Select objects")))) ; ans holds the button picked as an integer value
(cond
((if (= ans "All")(setq ss (ssget "_X" '((0 . "*TEXT"))))))
((if (= ans "All in tab")(setq ss (ssget "_X" '((0 . "*TEXT")(cons 410 (getvar 'ctab)))))))
((if (= ans "Select objects")(setq ss (ssget "_:L" '((0 . "*TEXT"))))))
If you don't want to use the "ans" value you can use the variable but, it is a number matching the button selected, so All would return but=1.
Multi radio buttons.lspFetching info...
Expand
@ronjonp thank you for correcting the errors and especially for the comments...
My knowledge of lisp programming is very limited...
Expand
@BIGAL Thank you for your suggestion and Multi radio buttons.lsp.
I'll try this method...
 (vl-load-com)
 (if (findfile (strcat (getenv "WINDIR") "\\FONTS\\ARIALN.ttf"))
 (if ss
Expand
For some reason, this code doesn't work.
; error: ActiveX Server returned an error: The parameter is required
Expand
Try the code above again .. I missed setting the 'ff' variable.
  • Thanks 1
Expand
@ronjonp Thank you very much, now the code works perfectly! Creative success in the new year!🎄🎉
Edited by Nikon
Expand
:beer:
