Interior Posted April 15, 2009 Posted April 15, 2009 Hi, How do you place tangent lines on the curve so the lines (stairs) are at right angles. The curve is a spline i have tried lots of different ways including making it a poly line but the lines at tangents are the issue. Image belows shows the problem thanks Quote
rkent Posted April 15, 2009 Posted April 15, 2009 Using the ARC command, after picking the third point of the first arc, hit enter or space-bar to go back into ARC, the following arc will be tangent to the first, hit enter again and keep picking arcs Quote
lpseifert Posted April 15, 2009 Posted April 15, 2009 You could try the Measure command using a block (stair tread). or maybe this will help ;; PLPERP.lsp starts a polyline perpendicular to any 2D curve at ;; the point picked. ;; Allows direct distance entry for first polyline segment, then ;; restores previous ortho setting and snap angle (if any). ;; by Bill Gilliss bill dot gilliss at aya.yale.edu ;; 3/20/2008 ;; Comments and suggestions always welcome. (defun c:plperp ( / e en obj param p1 p2 wp1 sa oldortho oldsnapang oldosmode olderror) (setq oldortho (getvar "orthomode") oldsnapang (getvar "snapang") oldosmode (getvar "osmode") olderror *error* ) (setq e (entsel "Select curve at point to start perpendicular (OSNAPS welcome):")) (setq en (car e) p1 (cadr e)) ;UCS point (setq p1 (osnap p1 "_nea")) (setq obj (vlax-ename->vla-object en)) (setq param (vlax-curve-getParamAtPoint obj (trans p1 1 0))) ;WCS point (setq fderiv (vlax-curve-getFirstDeriv obj param)) (setq sa (+ (* pi 0.5) (angle (trans '(0.0 0.0 0.0) 0 1) (trans fderiv 0 1)))) (setvar "snapang" sa) (setvar "orthomode" 1) (setq p2 (getpoint p1 "\nNext point:")) (setvar "orthomode" oldortho) (setvar "snapang" oldsnapang) (setvar "osmode" oldosmode) (setq *error* olderror) (command "pline" p1 p2) );defun (defun *error* (msg) (setvar "orthomode" oldortho) (setvar "snapang" oldsnapang) (setvar "osmode" oldosmode) (setq *error* olderror) ) (prompt "PLPERP loaded.") (princ) Quote
Arizona Posted April 15, 2009 Posted April 15, 2009 When attempting to draw a line perp to an arc or curved segment of a polyline, I often start my line at the "Center" of the arc segment, then end it where I need it and trim it later. That insures that the line is perpendicular to the arc. Quote
Interior Posted April 16, 2009 Author Posted April 16, 2009 is it possible to explain it a little bit simpler as I'm not great at cad and created what i have by trying. I was recommended to use the spline as it would create the best smooth curve the same as my hand drawings. sorry i should know how to do this but your help is greatly received. thanks Quote
lpseifert Posted April 16, 2009 Posted April 16, 2009 draw a vertical line the length of the stair tread (e.g. 4') make a block out of the line using the bottom endpoint the base point. Call it TREAD use the measure command as below Command: measure Select object to measure: select the spline Specify length of segment or [block]: Block Enter name of block to insert: TREAD Align block with object? [Yes/No] : Y Specify length of segment: 1 this will insert treads 1 unit apart along the spline Quote
Interior Posted April 17, 2009 Author Posted April 17, 2009 Thank you very much fixed it straight away Quote
