Hi good day !
Please help me revise this LISP. The lisp calculating the center of the blocks and use it as a basepoint. I want to revise which it will use the true basepoint on the blocks. hope anyone can get my point. thank you in advance have a great day ahead.
(defun C:ROB (/ SS LL UR MPT)
  (vl-load-com)
  (if (setq SS (ssget ":L"))
    (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))
      (setq obj (vlax-ename->vla-object ent))
      (vla-getboundingbox obj 'minpt 'maxpt)
      (setq LL (vlax-safearray->list minpt)
            UR (vlax-safearray->list maxpt)
            MPT (mapcar '/ (mapcar '+ LL UR) '(2 2 2))
      (vl-cmdf "_.Rotate" ent "" "_non" MPT pause)
Edited by SLW210
Added Code Tags!
Please use code tags for your code. (<> in the editor toolbar)
Might not work been out of the lisp game for a hot min. remember autocad need like 3dpoint or something. can just use the dxf directly. should work with BricsCAD.
(defun C:ROB (/ SS base)
  (vl-load-com)
  (if (setq SS (ssget '((0 . "INSERT") (410 . "Model"))))
      (setq base (cdr (assoc 10 ent)))
      (command "_.Rotate" ent "" "_non" base pause)
