Flatten
This routine will flatten a 3D drawing so that all Z values are set to zero. Although LDT has a specific function for this purpose, if you're using plain AutoCAD, this neat routine could save hours.
;   Flatten a 3D drawing
;   Written by Eduard
;   This command will set all elevations and points to zero, efectively flattening any 3D drawing.
(defun c:flat (/ total-nabor)
 (vl-load-com)
 (if
   (setq total-nabor (ssget "x" '((410 . "model"))))
      (setq total-nabor
       (mapcar 'vlax-ename->vla-object
         (mapcar 'cadr
           (ssnamex total-nabor)
         ) ;_ end of mapcar
       ) ;_ end of mapcar
      ) ;_ end of setq
      (foreach  i '(1e99 -1e99)
  (mapcar (function (lambda (x)
          (vla-move x
              (vlax-3d-point (list 0 0 0))
              (vlax-3d-point (list 0 0 i))
          ) ;_ end of vla-move
        ) ;_ end of lambda
    ) ;_ end of function
    total-nabor
  ) ;_ end of mapcar
      ) ;_ end of foreach
    ) ;_ end of progn
 ) ;_ end of if
) ;_ end of defun
Download flat.lsp 0.93 KB
See the original topic for more details.
  • 4 years later...
Below is a faster variation on the above:
(defun c:flat ( / doc org )
   (setq doc (vla-get-activedocument (vlax-get-acad-object))
         org (vlax-3D-point 0 0 0)
   (vlax-for blk (vla-get-blocks doc)
       (if (= :vlax-false (vla-get-isxref blk))
           (vlax-for obj blk
               (if (vlax-write-enabled-p obj)
                   (foreach elv '(1e99 -1e99) (vla-move obj org (vlax-3D-point 0 0 elv)))
   (vla-regen doc acallviewports)
(vl-load-com) (princ)
Edited by Lee Mac
  • 9 years later...
           (vlax-for obj blk
Expand
how to select required objects and not all objects.
You have managed to resurrect a thread from 12 years ago.
One option would be to isolate the objects you want to flatten from all the other objects in the drawing.  You are familiar with freezing layers are you not?
Expand
Maybe use the first post and supress "x" character ?
Expand
Today I am in a situation, which the mentors might have foreseen 12 years ago. Thanks for the archive.
Expand
I could not locate the "x" as I believe this is visual lisp and not autolisp
Attach a copy of the drawing to your next post.  If the file size is too large then upload it to a file sharing website like DropBox and post a link to it here.  Indicate what object(s) need to be flattened.  Perhaps someone here can accomplish the task and provide you a copy of the result.
  • 1 month later...
Hi!
Use
(setq total-nabor (ssget))
instead of
ssget without arguments will prompt the user to select objects through the AutoCAD general 'Select objects:' mechanism.
