SLW210 Posted December 13 Posted December 13 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Please post in the correct forum. 1 1 Quote
SLW210 Posted December 13 Posted December 13 Can you post an actual drawing? And explain what you want in more detail. Quote
pkenewell Posted December 13 Posted December 13 @Akanezuko If I'm interpreting you correctly - try this: (defun c:SelinPoly (/ es ob pts r ss) (if (and (setq es (entsel "\nSelect a polygon: ")) (= (cdr (assoc 0 (entget (car es)))) "LWPOLYLINE") ) (progn (setq ob (vlax-ename->vla-object (car es)) pts (vla-get-coordinates ob) pts (vlax-safearray->list (vlax-variant-value pts)) ) (while pts (setq r (cons (list (car pts) (cadr pts)) r) pts (cddr pts) ) ) (if (> (length r) 2) (progn (entdel (car es)) (setq ss (ssget "CP" r '((0 . "*POLYLINE")))) (entdel (car es)) (sssetfirst nil ss) ) (princ "\nSelected Polygon must be more than 2 points.") ) ) (princ "\nYou must select a Polygon.") ) (princ) ) 1 Quote
BIGAL Posted December 13 Posted December 13 Using VLAX can save a couple of lines when getting pline points. (setq r (vlax-get ob 'coordinates)) I tend to use this, I think it was a suggestion by Lee-Mac. (setq plent (entsel "\nPick rectang")) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) 2 Quote
Akanezuko Posted December 14 Author Posted December 14 11 hours ago, BIGAL said: Using VLAX can save a couple of lines when getting pline points. (setq r (vlax-get ob 'coordinates)) I tend to use this, I think it was a suggestion by Lee-Mac. (setq plent (entsel "\nPick rectang")) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) 18 hours ago, pkenewell said: @Akanezuko If I'm interpreting you correctly - try this: (defun c:SelinPoly (/ es ob pts r ss) (if (and (setq es (entsel "\nSelect a polygon: ")) (= (cdr (assoc 0 (entget (car es)))) "LWPOLYLINE") ) (progn (setq ob (vlax-ename->vla-object (car es)) pts (vla-get-coordinates ob) pts (vlax-safearray->list (vlax-variant-value pts)) ) (while pts (setq r (cons (list (car pts) (cadr pts)) r) pts (cddr pts) ) ) (if (> (length r) 2) (progn (entdel (car es)) (setq ss (ssget "CP" r '((0 . "*POLYLINE")))) (entdel (car es)) (sssetfirst nil ss) ) (princ "\nSelected Polygon must be more than 2 points.") ) ) (princ "\nYou must select a Polygon.") ) (princ) ) Thank you!!! 1 Quote
