SLW210 Posted December 13, 2024 Posted December 13, 2024 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Please post in the correct forum. 1 1 Quote
SLW210 Posted December 13, 2024 Posted December 13, 2024 Can you post an actual drawing? And explain what you want in more detail. Quote
pkenewell Posted December 13, 2024 Posted December 13, 2024 @Akanezuko If I'm interpreting you correctly - try this: (defun c:SelinPoly (/ es ob pts r ss) (if (and (setq es (entsel "\nSelect a polygon: ")) (= (cdr (assoc 0 (entget (car es)))) "LWPOLYLINE") ) (progn (setq ob (vlax-ename->vla-object (car es)) pts (vla-get-coordinates ob) pts (vlax-safearray->list (vlax-variant-value pts)) ) (while pts (setq r (cons (list (car pts) (cadr pts)) r) pts (cddr pts) ) ) (if (> (length r) 2) (progn (entdel (car es)) (setq ss (ssget "CP" r '((0 . "*POLYLINE")))) (entdel (car es)) (sssetfirst nil ss) ) (princ "\nSelected Polygon must be more than 2 points.") ) ) (princ "\nYou must select a Polygon.") ) (princ) ) 1 Quote
BIGAL Posted December 13, 2024 Posted December 13, 2024 Using VLAX can save a couple of lines when getting pline points. (setq r (vlax-get ob 'coordinates)) I tend to use this, I think it was a suggestion by Lee-Mac. (setq plent (entsel "\nPick rectang")) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) 2 Quote
Akanezuko Posted December 14, 2024 Author Posted December 14, 2024 On 12/13/2024 at 9:39 PM, BIGAL said: Using VLAX can save a couple of lines when getting pline points. (setq r (vlax-get ob 'coordinates)) I tend to use this, I think it was a suggestion by Lee-Mac. (setq plent (entsel "\nPick rectang")) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) Expand On 12/13/2024 at 2:17 PM, pkenewell said: @Akanezuko If I'm interpreting you correctly - try this: (defun c:SelinPoly (/ es ob pts r ss) (if (and (setq es (entsel "\nSelect a polygon: ")) (= (cdr (assoc 0 (entget (car es)))) "LWPOLYLINE") ) (progn (setq ob (vlax-ename->vla-object (car es)) pts (vla-get-coordinates ob) pts (vlax-safearray->list (vlax-variant-value pts)) ) (while pts (setq r (cons (list (car pts) (cadr pts)) r) pts (cddr pts) ) ) (if (> (length r) 2) (progn (entdel (car es)) (setq ss (ssget "CP" r '((0 . "*POLYLINE")))) (entdel (car es)) (sssetfirst nil ss) ) (princ "\nSelected Polygon must be more than 2 points.") ) ) (princ "\nYou must select a Polygon.") ) (princ) ) Expand Thank you!!! 1 Quote
