I need help reversing this AutoLisp
Archie_
I got this code from chatgpt, that chatgpt got from a defunct post from autocad website forums. Whenever I tried going to the website or googling, the link seems broken so I don't know how this code exactly works.
I am trying to make a Lisp that creates dimstyles from scratch. everything is working except for changing between annotative and non annotative. The code below does a good job of setting the created dimension style to annotative. But when I ask chat gpt to make it in reverse, i.e. make a code that makes the created dimstyle non annotative, it can't.
(defun set-dimstyle-annotative (dimstyle-name / ent entdata xdata)
  ;; Ensure the dimension style exists
  (if (and (setq ent (tblobjname "dimstyle" dimstyle-name))
           (setq entdata (entget ent)))
      ;; Check if XData for "AcadAnnotative" exists
      (if (not (assoc -3 entdata))
          ;; Add XData to set the dimension style as annotative
          (setq xdata
                '((-3
                   ("AcadAnnotative"
                    (1000 . "AnnotativeData")
                    (1002 . "{")
                    (1070 . 1)  ; Version number
                    (1070 . 1)  ; Annotative flag: 1 = Yes, 0 = No
                    (1002 . "}")
          ;; Apply the XData to the dimension style
          (entmod (append entdata xdata))
          (princ (strcat "\nDimension style '" dimstyle-name "' set to annotative."))
        (princ (strcat "\nDimension style '" dimstyle-name "' is already annotative."))
    (princ (strcat "\nDimension style '" dimstyle-name "' not found."))
Basically when a dimstyle is created, I put this at the end of the code to make it annotative. However, after making an annotative dimstyle, I can make a dimstyle, but because the previous was annotative, I cannot set the new dimstyle to non annotative. Chat gpt gave me a code but it seems it just butchered the code and it doesn't work.
I attached the lisp file. Thanks!!
DimStyles.lsp
Edited by SLW210
Added Code Tags!
