Hi Lee,
I still can not run the routine.
Command: ap
APPLOAD NumInc V2-9.lsp successfully loaded.
Command:
ø¤º°`°º¤ø NumInc.lsp ~ Copyright © by Lee McDonnell ø¤º°`°º¤ø
~¤~ ...Type "NumInc" to Invoke... ~¤~
Command:
Command: numinc
; error: bad argument type: stringp T
  • Replies 300
  • Lee Mac
    150
  • alanjt
    10
  • The Buzzard
    10
  • mdbdesign
    7
Posted Images
Thanks Lee.
Now it worked.
Guest kruuger
Hello Everyone,
I found Numinc.lsp and i want to say that...
THIS LISP IS AMAZING-UNBELIEVABLE-COOLEST DCL I EVER SEEN... THIS PROGRAM IS SICK:D
My suggestion. Can i?
Is it possible to back to DCL window to change increment/prefix/suffix and with OK button continue numbering?
Thank You
kruuger
Hi Kruuger,
I'm glad you like my program :)
I thank you for your feedback, but the user can just right-click, then re-invoke with perhaps another right-click and the previous settings are all displayed so that the user may alter them as necessary :)
Thanks
Lee
Guest kruuger
i was thinking about type D to back to dialog and for example reverse numbering. any way now also works great.
i'm reviewing your other programs, they are AWESOME!!!.
i can learn a lot from them:)
thanks
kruuger
Thanks Kruuger :)
I think you can already do reverse numbering, (if I understand what you are referring to), by using a negative increment :)
I may include your ideas in the next version :)
THIS program is Awesome LEE! What a time saver!
I have a question.
I am renumbering a lot of rooms within my building drawings, and many of the room names are incorrect. ( i.e. classroom, actually a Science lab)
Is it possible to add a optional prompt that asks the user for a room name upon each insertion of a number?
Of course there may be better way to do this! as you can see i am a n00b!
Hi Skybeorn,
Thanks for your post - I'm really glad you like the program and that it saves you some time :)
I don't particularly want to modify the program however to suit one user's needs, as this will affect how other users may use the program.
Lee
Lee,
I understand the knowledge behind your choice, and thanks for your response.
*_*
You're welcome - I'm sure there is enough code posted on this forum to satisfy your request :)
  • 1 month later...
  jcap91163 said:
one word AMAZING, many, many thanks
Thanks for you kind words - I'm glad you like it mate. :)
  • 1 month later...
Hi Lee,
I have Autocad 3D 2011. I downloaded your program but it's not working. Is this program compatible with this version of Autocad?
The below is displayed at the command. Please help me to get this to work. It looks like a very nice program. Thanks, Sdrawn.
Command: APPLOAD
Command: ; error: bad function: "0"
Hi SDrawn,
Thank you for your interest in my program, I shall look to see what may be causing your problem.
Lee
SDrawn,
For clairification:
1) Does the error occur immediately after loading (i.e. before you attempt to invoke the command)?
2) How are you loading the file, I would assume just saving the attachment and loading it. The reason I ask is that if the answer to 1) is 'yes', this would imply that code is running outside of the function definition, - this would occur if you were perhaps copying and pasting code and missing parts.
Thanks. With your help, I've got the program working now. You were right about copying & pasting and running the program outside of the function definition. Then... I returned to internet and downloaded & saved the program to my computer. It's working great now. Nice little program!
Glad you like it mate, I enjoyed writing it :)
I just found this. Nice work. I like how it can accomodate any attribute in my blocks, and can go sequentially with numbers or letters.
The real value for me is renumbering attributed blocks....room tags, door tags, equipment tags, column grids etc.
I found it a bit difficult for this at first....it took a bit to find the "replace" option....it's buried after a long string of options . I'd never use the "enclose text with" shapes/text options, since that makes two separate autocad entities...not a block. Since I was only using the "replace" option with blocks, I found the dialog box asking for text layer, style etc. confusing at first.....then I realized I could mostly ignore those settings since they had no effect on my blocks anyway. However, I was still forced to select a positive text height, even though it doesn't get used with "replace" for a block.
This could be a very useful tool for block users in my office, but I think the number of settings and options related to text only and the somewhat hidden "replace" option will be too much for novice users. I'd love to transform this into a simpler attributed block renumbering tool only. It might also be fantastic to have an option in such a tool to pick a pre-existing block in the drawing, and have it auto increment it as you insert that block additional times.
Congratulations on great work....I hope to have those kind of programming skills someday!
