Sure thing Lee Mac.
Once I am granted permission from the website, I would like to send you a pm.
Cheers,
  • Replies 300
  • Lee Mac
    150
  • alanjt
    10
  • The Buzzard
    10
  • mdbdesign
    7
Posted Images
Lee
  Lee Mac said:
The DCL file should be in the same post as the AutoNum LISP file :)
Here
So, uh, yeah, there it is right there. Right next to the the .lsp file. oops. works perfectly now. thanks.
I have updated the code for this program to Version 2.1.
This version fixes the issue raised in a previous post regarding the text replacement, and also gives the user the ability to increment alphabetical text.
The new code may be found here.
Enjoy,
Lee
Lee, are you start developing icons for all programs you do?:twisted:
I'm not too good at developing icons... I could try I suppose... o:)
Perfect, waiting for next (If you have time)
Suggest: add it to main program page.
Thanks Lee, I really appreciate.
A major update to this program - I have added the ability to enclose text with either a rectangle, circle or slot, with offset too.
The latest version may be found here - with some additional GIFs for you all to enjoy :D
Lee
Nice work on this. Haven't peeped it in a while.
Two things:
  1. Remove display on XRef layers for text placement.
  2. Account for non-wcs rotation.
Nice idea - will do :)
I thought I had accounted for non-wcs in an earlier version, but I shall definitely look into it.
Thanks Alan :thumbsup:
When I tested it, it was ignoring the UCS for rotation. If the UCS is set, you want the angle to match.
Oh right - I didn't know that (my CAD ignorance again...), I shall implement that. Thanks :)
:) No sweat.
UCS is generally used to emulate a zero rotation when the view has been rotated to something other than zero.
As far as the XRef layers go, one can't normally put objects on those layers. It would/could create extreme confusion. Plus it's a crap load of extra layers no one wants to wade through.
I don't use something like this very often, but I'm going to shelf mine and replace with yours for when I do. :)
Thanks mate, I appreciate it - I'm sure you'll agree that its a great feeling when you know that someone is making use of a program you've written.
Thanks for the info :thumbsup:
Following your feedback Alan, I have updated the code to Version 2.3 :)
:thumbsup: I'll give it a go later (almost bathtime for the girl).
