  Lee Mac said:
As quoted from the ACAD help file:
You are right. But for the record, I don't think I have ever seen entupd ever fail to regen when modifying an individual attribute entity.
  • Replies 300
  • Lee Mac
    150
  • alanjt
    10
  • The Buzzard
    10
  • mdbdesign
    7
Posted Images
OK, but I just wanted to be certain that it would work :)
  MikeP said:
no never mind. the last version was even better. It just depends on how you enter the info in. to create 1.1 - 1.2 - 1.3 - 1.4 and so on. Just enter "1." into the prefix. then, "1" into the middle, then use "1" as an increment. this will cause it it say "1." "1" = 1.1 - 1.2 - 1.3 hope that makes sense. you can still do anything like "Item 1." for the prefix to get a result of "Item 1.1" - "Item 1.2" and so on.
Thats, ok, til you get to 1.9...
  MikeP said:
now what would really be sick to see is if we could enter fields into one of the prefix, middle or suffix...
Fields? can you do that on '04?
_________________________________________________
  The Buzzard said:
I just found that I would need to set my units precision to 0 for it to work correctly.
I think setting it up as an option would be better.
What are your thoughts on this Lee?
I will have a think on this, I may try to incorporate both, without a toggle - I really don't want to clutter the DCL too much :)
Ok, this fixes a few things - you can now have everything except decimals with leading zeros.
what are you referring to? it goes 1.9 then 1.10. no issue here. the only issue I found is that shift + space does not work for me.
Hmmm... in the maths that I study, 1.9 always went to 2.0... :huh:
Do you have Express Tools?
The detection of "shift" is made by a function called "acet-sys-shift-down", which is an Express tools function.
Also, you do have to hold shift when pressing space.
Does the shift + tab work for you? If it doesn't work, what happens instead?
  The Buzzard said:
:DGood deal Lee!:D
Cheers Buzzard - I am working on the problem with decimals AND leading zeros... then all will be complete.
Ok, I believe this allows decimals with leading zeros.
Oh well thats exactly what I want it to do. 1.9, 1.10, 1.11, 1.12...
Im my work I need to label a lot of groups. Id actually be using more of "A.01, A.02...." to label all of my parts I see what you mean though.
Ahh, ok no worries :)
Lee, make some nice icon and I will add this routine to my toolbar (need icon created by you)
Haha - I haven't made an icon in a while :P I'll give it a shot :)
  • 4 weeks later...
Ok - I see several different versions. Which are the most current and do I need two items as in the first two you posted? Although I'm not usually stupid I am ignorant. ;o)
Loaded and used it - LOVE IT
Thanks Ryder :D :D
  • 1 month later...
I have updated the first post of this thread with a brand new version of this program.
As always, any thoughts, criticism (and of course, bug reports!) are welcome.
  • 2 weeks later...
I have updated this program here to include a counter toggle (as requested), and also some minor bug fixes and coding improvements :)
Lee
