Also for some reason the text angle changes in the middle of executing the program... :confused:
Text angle changing? Middle of which part?
  • Replies 306
  • Lee Mac
    153
  • alanjt
    10
  • The Buzzard
    10
  • mdbdesign
    7
Very nice, Lee.
You know what would make a program like this truly powerful? In addition the current option which creates new text, an option to edit existing text (or attributes).
Yes, CAB's Incremental Numbering Suite does this - but it takes a lot more coding to recognise the numbers within existing text :cry:
I suppose I could add one that replaces existing text/attributes, but to edit it may be hard.
OK, this version includes a Replace Text/MText/Attribute Option :)
Just type "R" or "r" during text placement.
Lee,
When I edit an attribute it works fine until you select outside the attribute and the numbers are inserted on a slight angle.
Also please see my previous post about the zero's in the suffix unless you did spot this (I am not sure).
Thanks,
The Buzzard
Forget about the angle thing.
I see what I did wrong.
I can't seem to replicate this... if you select outside the attribute, surely it will just exit the "replace text mode" and return to just standard placement?
Yes, thank you for this suggestion, I apologise for not replying - I am just thinking of the best way to implement it. :thumbsup:
No problem :)
Ok, sorry for all these new versions - but just added the facility to use Leading Zeros on the incrementing text :)
Perfectionists have nothing to appologize for.
Lee,
This is the greatest thing since the invention of the sandwich.
Now we can all eat our words and like too.
Lee,
Thanks Buzzard :)
It still can't edit existing text, but I think I shall have to leave that task to CAB - as I said earlier, it takes a ton more coding :)
But I am happy with this one so far :)
I'd like to second The Buzzard's praise.
Only one question: is it really necessary to regen after editing the text/attribute? Can't entupd be used?
I find entupd very unreliable - whereas a regen 9 times out of 10 works.
As quoted from the ACAD help file:
Note: If entupd is used on a nested entity (an entity within a block) or on a block that contains nested entities, some of the entities might not be regenerated. To ensure complete regeneration, you must invoke the REGEN command.
A minor update - fixes an issue brought to my attention when using decimal increments. Although this now relies on values of LUPREC, LUNITS, UNITMODE and DIMZIN (something to bear in mind).
is there a work around so that it wont rely on the units
maybe it can read the number of decimals you want in the increments box. and temporarily set the units to be that much. then once the command is finished it restores back to original.
I suppose I could do something like this, although you may end up with results say, with an increment of 0.5 of:
1.0, 1.5, 2.0
instead of
1, 1.5, 2
Hey Lee,
There goes your leading zero fix.
I enter a prefix: 01, middle: N, and suffix: 001 and end up with
01N001 01N2.0000 01N3.0000 01N4.0000 and so on.
Can the decimal add-on be made to an option with a toggle or something?
The Buzzard
I just found that I would need to set my units precision to 0 for it to work correctly.
I think setting it up as an option would be better.
What are your thoughts on this Lee?
1.0, 1.5, 2.0
instead of
1, 1.5, 2
no never mind. the last version was even better. It just depends on how you enter the info in. to create 1.1 - 1.2 - 1.3 - 1.4 and so on. Just enter "1." into the prefix. then, "1" into the middle, then use "1" as an increment. this will cause it it say "1." "1" = 1.1 - 1.2 - 1.3 hope that makes sense. you can still do anything like "Item 1." for the prefix to get a result of "Item 1.1" - "Item 1.2" and so on.
now what would really be sick to see is if we could enter fields into one of the prefix, middle or suffix...
