Can you make your tool insert a BLOCK (a car for example) and autonumber it?
There's quite a few other increment routines which do this. Some are written for particular block/attribute combinations, and others a bit more general. My AutoIncr routine does have the capability of inserting a block and setting an attribute inside it, unfortunately it's not as "smooth" to use as Lee's (and some of the others I've seen).
Maybe adding an Auto-Update selected text could be nice: Select a set of numbers (text) replace a number, and auto-update the other ones.
This is the biggest boon of my code. It remembers which objects were picked / created / selected at the time you made the increments (it simply places them in order in a group, with the settings saved to the group). Then allows you to rearrange / remove / insert / append at a later stage or edit the settings ... then renumbers the entire group.
What it doesn't do (yet) is replace only a portion of the text. That's one of the features I'm still working on.
  • 3 weeks later...
Hello,
I have no object catch in command numinc?
I'm not sure what you mean?
Sorry, I have AutoCAD in German. - I mean the Object Snap (Button F3).
Yes, ObjectSnap functionality is disabled when using the program in 'dynamic mode' - this is due to the program using a GrRead loop to track user input, hence disabling all standard AutoCAD functionality (such as ObjectSnap, Tracking, Ortho etc).
Uncheck the box 'Text Follows Cursor' and ObjectSnap will become available.
  • 3 months later...
  • 4 weeks later...
I have a problem. When I use the "Switches to Curve-Aligned Mode" with "C" I just can rotate the text 90° with the "P" key. But I can't switch it 180°.
That was never a feature of the program - the program will always orient text for maximum readability.
OK I see. But I have the problem that in Germany the text has to be readable from the right and not from the left. So I asked myself if I can edit the program code in this way that the text rotates 90° in the other direction with the "P" key. Then I would have the maximum readability for Germans :wink:
How did you editor such long program code ?Do you editor your code with vim ?
I usually edit my source code in vim ,but there is no syntax highlighting file for visual lisp
in vim.
in vim.
I usually use the Visual LISP IDE (VLIDE) provided with AutoCAD - it doesn't have the ability to collapse function definitions, but IMO is the best editor for LISP.
Lee
Lee
How come it sounds better when YOU say it? :lol:
when the code is very long ,I think code folding is necessary.visual lisp ide cannot fold code .my autocad is 2004
I manage without it...
I think you will be very tired if you do not use code folding when your source code is very long .
and you will be get very very tired when you read someone else's source code without code folding
if the source code is very long
I 've got one problem so far with NumInc lisp. When I copy and paste a number, it doesn't paste right near the cursor but far far away. I ve got mu ucs assigned maybe that's the problem. And Second question is how to change that lisp below to have prefixed number or maybe you could implement a leader in NumInc
(defun C:ld (/ num osm pt)
(setq osm (getvar "osmode"))
(setvar "osmode" 0)
(setvar "cmdecho" 0)
(setq num (getint "\nEnter an initial number: "))
(while
(setq pt (getpoint
"\nSpecify leader start point: (or hit ENTER to Exit) "))
(command "._leader" pt pause "" (itoa num) "")
(setq num (1+ num)))
(setvar "cmdecho" 1)
(setvar "osmode" osm)
(princ "\nStart command with LD")
