Rukuto Posted December 6 Posted December 6 I would like some help to create a function that would allow me to select a point in between two horizontal and/or vertical lines and it would give me the vertical and horizontal dimensions between those lines. It's a 2D drawing but some lines are of different z value. I have tried using chatgpt to create a code but it is not able to properly select the nearest line from my specified point (after running the command). This function is there in the new sketchup. I was hoping to use it to create internal dimensions in an architectural plan. Quote
pkenewell Posted December 6 Posted December 6 (edited) In newer versions since AutoCAD 2016, the DIM command can already do this. What do you need that is not in this feature? Edited December 6 by pkenewell 1 Quote
