Francesco79 Posted December 2, 2024 Posted December 2, 2024 Good afternoon everyone, I work for a company that deals with stone cladding and sometimes we need to indicate an oversizing of the pieces that can vary from 20, 50 or 100mm. When the pieces are few it is not a big problem but when they start to be 20 modifying all the dimensions of the pieces is quite laborious. Is there a lisp that makes the dimension show the real measurement of the piece above and the same measurement increased by 20, 50, or 100 mm below? Thank you very much in advance. P.S. I tried to use alternative measurements but without success. Quote
BIGAL Posted December 2, 2024 Posted December 2, 2024 (edited) Welcome aboard. It could be as simple as this code, make a few defunc c:d-20, c:d-50 etc. It converts existing dimensions. ; https://www.cadtutor.net/forum/topic/94496-dimensions-lisp/ (defun c:D-20 ( / ss x obj) (setq ss (ssget '((0 . "DIMENSION")))) (if (= ss nil) (progn (alert "You have not picked dimensions \nWill now exit")(exit)) ) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (1- x))))) (setq len (+ 20. (vlax-get obj 'measurement))) (vlax-put obj 'textoverride (strcat "<>\n" (rtos len 2 3))) ) (princ) ) Do you know anything about lisp ? Edited December 2, 2024 by BIGAL Quote
