Hello!
The title says it all.
Can you recommend me an pluging that enebles an faster layout creation compared to  doing it all manualy in autocad.
im asking this becasue i strated using SheetSetManager more and more, but its geting boring and time consuming creating layouts the defualt way in Autocad.
Your opinions/reviews would be more then welcome.
Thank you
Making layouts quickly depends on what the layouts are showing, in the case of a CIvil dwg, you can walk along a pline and make layouts with viewports that match a desired scale including rotation. You can pick a point in model and enter a scale and a layout is made for a parts type dwg.
So explain more what is in your layouts.
Im 100% in architectual drawings.
I have usualy many A3 sheets of floorplans and sections
  • 2 weeks later...
Look through your work and find ones that you like, and which include the layers which are your standards.
Including dimstyles, visual and text styles.
Multiple Layouts, set up as you usually like them.
Then you can always hit the ground running, each time you start a project.
Save a few of them as .DWT  files, or even as .DWS  (Drawing Standards Files).
Talking to Butch via email putting something together. based on this starting point and pick point in model, layout made and mview created at correct scale.
  • Like 2
