DimCh Posted November 29 Posted November 29 Hello Guys, i'm a new user of ZWCAD 2025 (I was using Autocad 2017 till now). Maybe any of you could help me with a problem i have while I am trying to load a lisp in ZWCAD 2025 and after loading lisp and trying to use it i take back the message " ZWCAD setvar reject: vtenable 7 " in command list. Anyone knows what is the reason ?? (Lisp "runs" without a problem in Autocad) Quote
Tharwat Posted November 29 Posted November 29 That system variable is not supported in that ZWcad so just comment the codes related from the file which means not to be valuated / loaded so no failure up to that step. Quote
BIGAL Posted November 30 Posted November 30 Likewise in Bricscad some things are not there and you need to do a workaround. Post the line of code with the setvar so can see which variable your trying to set. Quote
