Arrange rectangles ?
Mountain_XD
Hi @Mountain_XD,
Try this:
(prompt "\To run a LISP type: DISP")
(defun c:DISP ( / dist base_dist ss len i ename)
  (setq dist (getreal "\nEnter the value for equal displacement:"))
  (setq base_dist dist)
  (prompt "\nSelect entities for displacement:")
  (setq ss (ssget))
  (setq len (sslength ss)
	i 0
  (while (< i len)
    (setq ename (ssname ss i))
    (command "._move" ename "" "d" dist)
    (setq dist (+ dist base_dist))
    (setq i (1+ i))
  (prompt "\The displacement were done.")
When entering a value for "equal displacement" it can be negative or positive value (eg. "-10" will displacement selected entities to the left side, "+10" to the right side). First, select the "green" rectangles to displacement, then run LISP again and select everything inside the "green" rectangle.
Best regards.
Thank you so much Saxlle
The first problem is that the first rectangle doesn't move. The second, is there any way to make the objects inside that rectangle move at the same time?
Try this modification, you just need to select all the rectangles and do NOT select anything inside them:
(defun c:DISP ( / dist base_dist ss len i ename coords ssn ssn_len)
  (prompt "\nSelect RECTANGLES entities for displacement:")
  (setq ss (ssget))
	i 0
  (while (< i len)
    (setq coords (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ename))))
    (setq ssn (ssget "WP" coords))
    (setq ssn_len (sslength ssn))
    (repeat ssn_len
      (command "._move" (ssname ssn (setq ssn_len (1- ssn_len))) "" "d" dist)
    (setq i (1+ i))
The above update code will solve that.
I don't see why do you need to displacement first rectangle? But, i tried with first rectangle and it works for me.
Edited by Saxlle
Edited a code for multiple entities displacement inside of rectangle
Hi @Mountain_XD
Last modification:
; Functions     :  DISP
; Description   :  Equal displacement of the RECTANGLES and everything inside them
; Author        :  SAXLLE
; Date          :  November 21, 2024
; Update 1.0    :  Added value to Y and Z to create list with variable dist -- > (list dist 0.0 0.0)
; Update date   :  November 22, 2024
  (setq ss (ssget))
	i 0
  (while (< i len)
    (command "._move" ename "" "d" (list dist 0.0 0.0))
    (repeat ssn_len
      (command "._move" (ssname ssn (setq ssn_len (1- ssn_len))) "" "d" (list dist 0.0 0.0))
    (setq i (1+ i))
I checked the dwg, ran the latest updated lisp and everything works fine. Try it and see if it works for you?
Also, see the attached video.
Best regards.
