robierzo Posted November 20, 2024 Posted November 20, 2024 Hi. I have installed the 2021 version of autocad. It doesn't allow me to save my applications to the support folder. How can I fix this? Thanks!!! Quote
Steven P Posted November 20, 2024 Posted November 20, 2024 Can you save there from other applications, perhaps a small notepad text file? If not and assuming it is a work computer, perhaps you need to check your IT support that you have the relevant permissions to do so 1 Quote
Tharwat Posted November 20, 2024 Posted November 20, 2024 Right click on the folder and then properties and after that you need to take full control to be able to write to that folder. Note: if that didn't work you may go back to AutoCAD folder to apply the same procedure. 1 Quote
robierzo Posted November 20, 2024 Author Posted November 20, 2024 19 minutes ago, Tharwat said: Right click on the folder and then properties and after that you need to take full control to be able to write to that folder. Note: if that didn't work you may go back to AutoCAD folder to apply the same procedure. O.K. Thanks. I changed the permissions and it worked. Thanks. Quote
Tharwat Posted November 20, 2024 Posted November 20, 2024 1 hour ago, robierzo said: O.K. Thanks. I changed the permissions and it worked. Thanks. You are welcome anytime. Quote
