JoeQuinn31 Posted November 14, 2024 Posted November 14, 2024 (edited) In this example, how do I grab all three bottom blue squares to stretch all three lines down at the same time? Holding Shift while I click all of them doesn't select multiple (they don't turn red). It used to work but I think I changed a system variable yesterday when trying to fix another text box issue. Edited November 14, 2024 by JoeQuinn31 set tag to 'question' Quote
SLW210 Posted November 14, 2024 Posted November 14, 2024 Default is red, but that can be changed with GRIPHOT sysvar. I do not think the standard sysvars have much to do with whether they select or not, but here are the grip related sysvars. AutoCAD 2022 Help | Commands for Editing with Grips | Autodesk And for selecting objects, AutoCAD 2022 Help | Commands for Selecting Objects | Autodesk Do you have Raster Design installed? If so, Shift+Left Click Select may be the issue. Quote
