B4DW01F Posted November 13, 2024 Posted November 13, 2024 (edited) I have done the same install several times but only this time i get a new error Cannot invoke (command) from *error* without prior call to (*push-error-using-command*). Converting (command) calls to (command-s) is recommended. Never had this before, i rad online some saying that if you replace the (command) with (command-s) in in the error lisp it fixes it but instead I get error Cannot invoke (command) from *error* without prior call to (*push-error-using-command*). Converting (command) calls to (command-s) is recommended. Here is the lisp i am trying to load, been using it for over 20 years and never had this issue. (DEFUN C:ELR (/ pt1);START ELR (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/27/00 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "ELR" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END ELR (DEFUN C:ELL (/ pt1);START ELL (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/27/00 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "ELL" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END ELL (DEFUN C:GRIDMARK (/ pt1);START GRIDMARK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/27/00 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "MARK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END GRIDMARK (DEFUN C:STEP (/ pt1);START STEP (ADDED 5/4/00, DJR) (load "error") (initerr) (setq sc (getvar "DIMSCALE")) (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "STEP" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END STEP (DEFUN C:SUB-SBSB (/ pt1);SUB-SBSB (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/27/00 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "SUB-SBSB" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END SUB-SBSB (DEFUN C:REF1 (/ pt1);REF1 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 5/31/01 (setvar "cmdecho" 0) (setvar "attdia" 1) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "REF1" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END REF1 (DEFUN C:REF2 (/ pt1);REF2 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 5/31/01 (setvar "cmdecho" 0) (setvar "attdia" 1) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "REF2" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END REF2 (DEFUN C:DATA (/ pt1);START OF DATA (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 6/1/01 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "DATA" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END DATA (DEFUN C:LAP (/ pt1);START OF LAP (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 6/1/01 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "LAPSCHED" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END LAP (DEFUN C:A615 (/ pt1);START OF A615 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 6/1/01 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "A615" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END A615 (DEFUN C:GRADE40 (/ pt1);START OF GRADE40 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 6/1/01 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "GRADE40" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END GRADE40 (DEFUN C:A706 (/ pt1);START OF A706 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 6/1/01 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "A706" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END A706 (DEFUN C:NOTE2 (/ pt1);START NOTE2 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/27/00 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "NOTE2" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END NOTE2 (DEFUN C:NOTE (/ pt1);START NOTE (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/27/00 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "NOTE" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END NOTE (DEFUN C:BARLISTINFO (/ pt1);START BARLISTINFO (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/27/00 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "BARLISTINFO" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END BARLISTINFO (DEFUN C:BARBENDINFO (/ pt1);START BARBENDINFO (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/27/00 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "BARLISTINFO" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END BARBENDINFO (DEFUN C:spec (/ pt1);START SPEC (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/27/00 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "SPECIALBAR" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END SPEC (DEFUN C:1-16SCBLOCK (/ pt1);START OF 1-16SCBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "1-16SCBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 1-16SCBLOCK (DEFUN C:1-2SCBLOCK (/ pt1);START OF 1-2SCBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "1-2SCBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 1-2SCBLOCK (DEFUN C:1-4SCBLOCK (/ pt1);START OF 1-4SCBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "1-4SCBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 1-4SCBLOCK (DEFUN C:1-8SCBLOCK (/ pt1);START OF 1-8SCBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "1-8SCBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 1-8SCBLOCK (DEFUN C:1SCBLOCK (/ pt1);START OF 1SCBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "1SCBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 1SCBLOCK (DEFUN C:3-16SCBLOCK (/ pt1);START OF 3-16SCBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "3-16SCBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 3-16SCBLOCK (DEFUN C:3-32SCBLOCK (/ pt1);START OF 3-32SCBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "3-32SCBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 3-32SCBLOCK (DEFUN C:3-4SCBLOCK (/ pt1);START OF 3-4SCBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "3-4SCBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 3-4SCBLOCK (DEFUN C:3-8SCBLOCK (/ pt1);START OF 3-8SCBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "3-8SCBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 3-8SCBLOCK (DEFUN C:HEADER1 (/ pt1);START OF HEADER1 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "HEADER1" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END HEADER1 (DEFUN C:HEADER2 (/ pt1);START OF HEADER2 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "HEADER2" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END HEADER2 (DEFUN C:HEADER3 (/ pt1);START OF HEADER3 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "HEADER3" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END HEADER3 (DEFUN C:22X34 (/ pt1);START OF 22X34 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "22X34" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 22X34 (DEFUN C:30X42 (/ pt1);START OF 30X42 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "30X42" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END 30X42 (DEFUN C:TXTPT (/ pt1);START OF TXTPT (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "TXTPT" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END TXTPT (DEFUN C:AL11X17 (/ pt1);START OF AL11X17 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "AL11X17" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END AL11X17 (DEFUN C:AIRBLOCK (/ pt1);START OF AIRBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "AIRBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END AIRBLOCK (DEFUN C:FS11X17 (/ pt1);START OF FS11X17 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "FS11X17" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END FS11X17 (DEFUN C:AS11X17 (/ pt1);START OF AS11X17 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "AS11X17" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END AS11X17 (DEFUN C:PREFORM (/ pt1);START OF PREFORM (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "PREFORM" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END PREFORM (DEFUN C:AIRBLOCK (/ pt1);START OF AIRBLOCK (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "AIRBLOCK" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END AIRBLOCK (DEFUN C:AL22X34 (/ pt1);START OF AL22X34 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "AL22X34" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END AL22X34 (DEFUN C:coast11X17 (/ pt1);START OF coast11X17 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "coast11X17" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END coast11X17 (DEFUN C:coast18X24 (/ pt1);START OF coast18X24 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "coast18X24" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END coast18X24 (DEFUN C:coast30X42 (/ pt1);START OF coast30X42 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "coast30X42" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END coast30X42 (DEFUN C:CMC11X17 (/ pt1);START OF CMC11X17 (load "error") (initerr) (setq sc (getvar "DIMSCALE"));REV 1/16/03 (setvar "cmdecho" 0) (setq pt1 (getpoint "\nInsertion Point: ")) (prompt "\nRotation Angle: ") (COMMAND "INSERT" "CMC11X17" pt1 SC"" PAUSE) (IF(= METRIC T) (COMMAND "SCALE" "L" "" pt1 25.4)) (reset nil) );END CMC11X17 ;END INSERTFILES.LSP Edited November 14, 2024 by SLW210 Added Code Tags!! Quote
B4DW01F Posted November 14, 2024 Author Posted November 14, 2024 also noticed that when i added "directories" into the search path it isnt populating the "working" search path like normal Quote
SLW210 Posted November 14, 2024 Posted November 14, 2024 In the future please use Code Tags for your Code. (<> in the editor toolbar) Quote
Steven P Posted November 14, 2024 Posted November 14, 2024 I'll assume that the LISP file loads OK being in a trusted location, with appload or similar? Is it all the routines in the file or just a specific routine? Quote
rlx Posted November 14, 2024 Posted November 14, 2024 you could try : (vl-catch-all-apply 'vl-cmdf (list "-INSERT" "A706" pt1 SC"" PAUSE)) and note the - in front of insert Quote
pkenewell Posted November 14, 2024 Posted November 14, 2024 @B4DW01F I recommend you post the relevant functions in your "error" Lisp you are loading. I suspect the problem is there rather than the functions you posted. Quote
B4DW01F Posted November 14, 2024 Author Posted November 14, 2024 (edited) 9 hours ago, pkenewell said: @B4DW01F I recommend you post the relevant functions in your "error" Lisp you are loading. I suspect the problem is there rather than the functions you posted. ;* AutoLISP Files for Inside AutoLISP IL DISK - (c) 1987, 1988, 1989 ;* New Riders Publishing. All Rights Reserved. Version 10.00 for PC-DOS/MS-DOS ;* Developed by Rustin Gesner, Patrick Haessly and Joseph Smith ;* ;* ERROR.LSP ;* The *ERROR* function is designed to maintain the system's integrity. The main ;* function executes each item on the #error list. The list must be a valid LISP ;* expression. The error list can be modified throughout the course of a ;* program using ADDERR and DELERR. INITERR resets the #error list to your ;* standard settings. RESET resets the environment. It can be called at the end ;* of a program. ;* ;* INITERR sets default #ERROR list for resetting environment and/or error recovery (defun initerr () (setq #error (append '((setvar "BLIPMODE" 0)) ;blipmode should be OFF '((setvar "CMDECHO" 1)) ;command echo on '((setvar "MENUECHO" 0)) ;menu echo on '((setvar "OSMODE" 675)) ;snap none '((setvar "HIGHLIGHT" 1)) ;highlight on '((setvar "ATTDIA" 0)) ; 2-10-97 DV ));setq );defun ;* ADDERR adds one item to the #ERROR list. ITEM must be quoted expression, ;* or in form: (list 'FUNCTION arg arg arg...) where arguments are quoted or ;* not depending on whether you pass the current value or use them literally. (defun adderr (item) (if (not (member item #error)) ;if it's not a duplicate item (setq #error (cons item #error)) ;add it to the list );if );defun ;* ;* DELERR deletes one item from the #ERROR list. ITEM is same format as ADDERR. (defun delerr (item) (setq #error (subst '() item #error)) ;replace item with a null list );defun ;* ;* #ERR stores the original standard error function, before it gets redefined. ;(if #err nil (setq #err *error*)) ;* *ERROR* redefines the standard error function. (defun *error* (msg) (command nil nil nil) ;cancels any pending command (reset msg) ;processes #ERROR list, restoring environment ;(grtext) ;clear the graphics text boxes ;Check the type of error. If user did not cancel program, ;use standard message. Otherwise, it's a program bug. ;(if (and (/= msg "console break") (/= msg "Function canceled")) ;compare messages ;(progn ;then program bug ;(grclear) ;clear the graphics screen ;(grtext -1 "Program ERROR!") ;prompt the user in status box ;);progn ;);if (princ) );defun *ERROR* ;* ;* RESET function resets the standard environment. You can call it at the end ;* of a function to put the settings back in order, including any tasks you ;* ADDERR but do not DELERR. If you call it from a function for normal ;* termination, pass it a NIL argument. (defun reset (msg / x) (if msg (prompt (strcat "Error: " msg "\n")) ;print out error message (prompt "\nResetting environment... ") ) (setq x 1) ;sets the counter x (foreach func #error ;loops through error items (eval func) ;evaluates each one ;(grtext -2 (strcat "Reset " (itoa x))) ;Shows user a running count of (setq x (1+ x)) ;the number of items reset );foreach (initerr) ;resets default #ERROR list (princ) );defun RESET ;* ;* C:*ERROR* restores the standard AutoLISP *ERROR* function for testing, ;* using the #ERR variable which stored *ERROR* at the top of ERROR.LSP. ;(defun C:*ERROR* () (setq *error* #err)) (princ) ;* End of ERROR.LSP ;* Edited November 14, 2024 by B4DW01F Quote
B4DW01F Posted November 14, 2024 Author Posted November 14, 2024 11 hours ago, Steven P said: I'll assume that the LISP file loads OK being in a trusted location, with appload or similar? Is it all the routines in the file or just a specific routine? Yes it is in a trusted location and added to the search path directories, but i noticed autocad isnt populating the "working" search path like normal Quote
pkenewell Posted November 15, 2024 Posted November 15, 2024 @B4DW01F Look in your *error* defun: Change This: (command nil nil nil) to This: (command-s nil nil nil) Quote
