I'm working on a startup lisp for when I open a dwg. So far I've just got a few command like audit in it. I'm wanting to have the current layer set to TXT-100 when it's opened. But I don't know how it is written in lisp.:unsure: I always like to see what autocad process is when it does something before I write a script, but I found that the command line doesn't return anything when you change what your current layer is. Any feedback would be appreciated.
I would check its existence and use this:
(if (tblsearch "LAYER" "TXT-100")
 (setvar "CLAYER" "TXT-100"))
Put this in your opening lisp code - adjust to suit
(if(not (tblsearch "LAYER" "TXT-100"))
(command "-layer" "new" "TXT-100" "Color" 7 "TXT-100" "LTYPE" "Continuous" "TXT-100" ""));end if
Thanks for the info on this! Now I won't end up plotting on the 0 layer and get a blank sheet of paper! lol:lol:
