Select Group, in a window selection
Hi all,
How do I select groups in a window selection?
I found this, but it select all groups in the drawing. I don't want all groups in the drawing, but only those in my window selection.
; Return: selection set of entities that make up all
; defined groups or nil
(defun JRP:Groupss (/ Tmp Lst ss)
(if (setq Tmp (massoc 350 (dictsearch (namedobjdict) "acad_group")))
(setq ss (ssadd))
(foreach x Tmp (setq Lst (cons (massoc 340 (entget x)) Lst)))
(foreach x Lst (foreach y x (ssadd y ss)))
(if (> (sslength ss) 0) ss)
(defun massoc (key alist / x nlist)
(foreach x alist
(if (eq key (car x))
(setq nlist (cons (cdr x) nlist))
(reverse nlist)
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/ssget-group-selection/td-p/822248
Edited by SLW210
Added Code Tags!
In the future please use code tags for your code. (<> in the editor toolbar)
This creates a selectionset ss for you to use like : (sslength ss) or on command line : erase (eval ss) etc
(defun c:test ( / r)(if (vl-consp (setq r (get)))(progn (setq ss (ssadd))(foreach e r (ssadd e ss)))))
(defun get ( / s l) (if (setq s (ssget))
  (foreach e (mapcar 'cadr (ssnamex s))(if (ggn e)(progn (redraw e 3)(setq l (cons e l)))))) l)
(defun ggn (o / m g) (setq g (vla-get-groups (vla-get-activedocument (vlax-get-acad-object))))
  (if (= (type o) 'ENAME) (setq o (vlax-ename->vla-object o)))
    (vlax-for x g (vlax-for y x (if (equal o y)(setq m (cons (vlax-get x 'Name) m))))) m)
Edited by rlx
Work beautifully. Thank you rlx. Great quality of life improvement at work for me.
