jim78b Posted November 6 Posted November 6 I noticed that if I do the following: Isolate the block, then I refedit and exit the block autocad draws unselectable ghost blocks (in grey). Does anyone of you have the same problem? Quote
SLW210 Posted November 6 Posted November 6 Did you contact Autodesk? This happened several years ago and they did an update to fix it. Not sure what version it was. Did you check your graphics card and drivers? Ghosted, dragged, or duplicated objects appear in AutoCAD 3D objects disappear, display wrong, shift position, move, or offset from grips in AutoCAD 1 Quote
jim78b Posted November 6 Author Posted November 6 Yes is a bug .if i disable hardware accelleration they vanish. Quote
