jakebullet70 Posted April 7, 2009 Posted April 7, 2009 Hi all I am using this code to grab 2 points v1 = ThisDrawing.Utility.GetPoint(, vbCr & "Select Point 1: ") v2 = ThisDrawing.Utility.GetPoint(, vbCr & "Select Point 2: ") The points selected can be at any angle. Now... In certain situations I need to take 18 inches off of each side. I used v1(0) + 18 and V1(1) - 18 and this works if the line is horizontal but that wont work once the line angle changes. Any ideas? BTW, I am not an Acad programmer, Work is slow and this stuff was just tossed on my desk. Thanks to all!!! Quote
SEANT Posted April 7, 2009 Posted April 7, 2009 I'm not sure I'm following. Your example of reducing each side of a horizontal by 18 would seem more appropriate with v1(0) + 18 and v2(0) – 18. Am I not following the objective of the routine? Quote
jakebullet70 Posted April 7, 2009 Author Posted April 7, 2009 I'm not sure I'm following. Your example of reducing each side of a horizontal by 18 would seem more appropriate with v1(0) + 18 and v2(0) – 18. Am I not following the objective of the routine? Your right, I typed it to the forum wrong. So I am using: p_vPoint1(0) = (v1(0) + 18) p_vPoint2(0) = (v2(0) - 18) And that works as long as the line is horizontal but once it goes vertical its all wonky... Quote
SEANT Posted April 7, 2009 Posted April 7, 2009 Something like the example shown should allow for points at arbitrary angles. Option Explicit Const pi As Double = 3.14159265 Sub reduceBy18() Dim v1 As Variant Dim v2 As Variant Dim dblAng As Double Dim entLine As AcadLine With ThisDrawing.Utility v1 = .GetPoint(, "Select point 1: ") v2 = .GetPoint(v1, "Select point 2: ") dblAng = .AngleFromXAxis(v1, v2) v1 = .PolarPoint(v1, dblAng, 18#) v2 = .PolarPoint(v2, dblAng + pi, 18#) Set entLine = ThisDrawing.ModelSpace.AddLine(v1, v2) End With End Sub Quote
jakebullet70 Posted April 7, 2009 Author Posted April 7, 2009 SEANT!!!! Thanks a bunch!!! That works great!!!! Quote
SEANT Posted April 7, 2009 Posted April 7, 2009 You're welcome. I should point out that the routine is only compatible with points at a common elevation in the WCS. Additional processing would be required to account for full 3D point selection. Quote
