I have the following code, I am trying to replace / update a block definition that is already in the current drawing. I get stuck at redefining part within the command line. Anyway around that?
(defun c:test (/ ss basept blockname blkDef blkUsed)
  (setq blockname "test")
  (if (setq blkDef (tblobjname "block" blockname))
    (if (setq blkUsed (ssget "x" (list (cons 0 "INSERT") (cons 2 blockname))))
        (princ (strcat "\nBlock " blockname " already exists. Purging and redefining..."))
        (entdel blkDef)
  (princ "\nSelect object for the block: ")
  (if (setq ss (ssget))
      (setq basept (getpoint "\nSpecify base point for the block: "))
      (command "_.-block" blockname basept ss "")
      (command "_.-insert" blockname basept "" "" "")
(princ))
Yes or No, please.
; error: Function cancelled
Redefine it? [Yes/No] <N>: y Specify insertion base point or [Annotative/mOde]: *Cancel*
Thanks a bunch!
start your code with (setvar "expert" 5) should suppress yes / no question , just put original value back at end of your program
