Quickly remove Objects on Block with swept selected object, but can not undo when a mistake select Object
This is a lisp use remove Object on Block but When I make a mistake select Object  i can not undo. Somebody Help me this problem. Thank you so much !
Here code :
EraseObjectFromBlock.LSP
Have you tied:
Undo, then REGEN.
It seems like without a REGEN it appears like undu isn't working.
Is that good enough of an answer?
