muck Posted April 7, 2009 Posted April 7, 2009 AutoCAD 2000 or above Does the two statement select all entities in a drawing or are they good for only the current model/paper space? Set ssetObj = ThisDrawing.SelectionSets.Add("SS1") ssetObj.Select acSelectionSetAll If only in current space, How do I select all entities in a drawing? thank you, Quote
CmdrDuh Posted April 7, 2009 Posted April 7, 2009 if that doesn't work, you will have to step through each layout tab and grab the objects in that space Quote
