masterfal Posted October 24, 2024 Posted October 24, 2024 Hi All, Was wondering if anyone was able to slightly tweak this routine so that snaps work while the command is running and you are placing the text? Not sure if its a simple thing to add in or not.. Cheers! (as usual, props to lee mac for setting up of course) NumIncV3-9.lsp Quote
masterfal Posted October 24, 2024 Author Posted October 24, 2024 2 minutes ago, masterfal said: Hi All, Was wondering if anyone was able to slightly tweak this routine so that snaps work while the command is running and you are placing the text? Not sure if its a simple thing to add in or not.. Cheers! (as usual, props to lee mac for setting up of course) NumIncV3-9.lsp 296.3 kB · 0 downloads doh Quote
dexus Posted October 24, 2024 Posted October 24, 2024 I tried to change the code to use https://www.lee-mac.com/grsnap.html It kind of works, but flickers a lot because I have to hide the text so it won't snap to itself. Its not optimal, but you might prefer it. Here is what lines to add and the positions where to add it: ;line 2178: ( (member g1 '(3 5)) (redraw) (vla-put-Visible bor :vlax-false) (vla-put-Visible obj :vlax-false) (vla-update bor) (vla-update obj) (setq g2 (SnapFunction g2 SnapMode)) (vla-put-Visible bor :vlax-true) (vla-put-Visible obj :vlax-true) (vla-update bor) (vla-update obj) ;line 2179 (setq p1 (vlax-3D-point (trans g2 1 0))) and: ; line 558 (cond ( (not (and LM:grsnap:snapfunction (member (type LM:grsnap:snapfunction) '(subr usubr exrxsubr)) (setq SnapFunction (LM:grsnap:snapfunction)) (setq SnapMode (getvar 'osmode)) ) ) (princ "\ngrsnap functions not loaded.") ) ; line 559 ( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer)))))) Of couse, grsnap should be loaded beforehand for this to work. Quote
