Click a Button, Perform an Action on the Drawing, and Return to the DCL
I have a question that has likely been answered before, but I couldn’t find it.
I want to click a button, select an entity in the drawing, get the distance, and then return to the dialog box with the information written in the edit_box. What’s the best way to do this? Could someone provide an example?
(defun c:OpenDCLDialog ( / dcl_id)
  (setq dcl_id (load_dialog "example_dialog.dcl"))
  (if (not (new_dialog "example_dialog" dcl_id))
    (exit)
  (action_tile "select_btn" "(done_dialog 2)")
  (action_tile "ok_btn" "(done_dialog 1)")
  (setq dclflag (start_dialog))
  (cond
    ( (eq dclflag 2)
      (:select)
    ((eq dclflag 2)
      (prompt "ok!")
  (unload_dialog dcl_id)
(defun :select ()
  (setq entity (car (entsel "\nSelect an entity: ")))
  (setq ponto (assoc 10 (entget entity)))
  (setq dist (getdist (cdr ponto) "Distance: "))
  ;;vou fazer algo aqui
;;(c:OpenDCLDialog)
example_dialog : dialog {
    label = "Entity Selection Example";
    : row {
        : edit_box {
            key = "distance";
            label = "Distance";
            edit_width = 25;
    : row {
        : button {
            key = "select_btn";
            label = "Select Entity";
    : row {
        : button {
            key = "ok_btn";
            label = "OK";
            is_default = true;
        : button {
            key = "cancel_btn";
            label = "Cancel";
            is_cancel = true;
You are correct you have to close the dcl and reopen it. the key is distance so (set_tile "distance" dist)  the dist would be the object length as a string maybe need to check, when you start dcl the dist
(if (= dist nil)
(setq dist "0")
(setq dist (rtos len 2 2))
Edited by BIGAL
Hi
Use a while loop to re-open the dialog if "Select" button is picked.
Like this
(defun c:OpenDCLDialog ( / dcl_id dclflag dst)
  (setq dclflag 2)
  (if
    (and
      (> dcl_id 0)
      (while
        (> dclflag 1)
        (if dst (set_tile "distance" dst))
        (action_tile "distance" "(setq dst $value)")
        (if
          (and
            (= dclflag 2)
            (setq dst (:select))
          (setq dst (rtos dst))
      );while
      (if
        (= dclflag 1)
        (distof dst)
    );progn
(defun :select ()
  • Thanks 1
@Stefan BMR Thank you, that's what I needed.
