Anushka Posted October 23, 2024 Posted October 23, 2024 I have a question that has likely been answered before, but I couldn’t find it. I want to click a button, select an entity in the drawing, get the distance, and then return to the dialog box with the information written in the edit_box. What’s the best way to do this? Could someone provide an example? (defun c:OpenDCLDialog ( / dcl_id) (setq dcl_id (load_dialog "example_dialog.dcl")) (if (not (new_dialog "example_dialog" dcl_id)) (exit) ) (action_tile "select_btn" "(done_dialog 2)") (action_tile "ok_btn" "(done_dialog 1)") (setq dclflag (start_dialog)) (cond ( (eq dclflag 2) (:select) ) ((eq dclflag 2) (prompt "ok!") ) ) (unload_dialog dcl_id) ) (defun :select () (setq entity (car (entsel "\nSelect an entity: "))) (setq ponto (assoc 10 (entget entity))) (setq dist (getdist (cdr ponto) "Distance: ")) ;;vou fazer algo aqui ) ;;(c:OpenDCLDialog) example_dialog : dialog { label = "Entity Selection Example"; : row { : edit_box { key = "distance"; label = "Distance"; edit_width = 25; } } : row { : button { key = "select_btn"; label = "Select Entity"; } } : row { : button { key = "ok_btn"; label = "OK"; is_default = true; } : button { key = "cancel_btn"; label = "Cancel"; is_cancel = true; } } } Quote
BIGAL Posted October 23, 2024 Posted October 23, 2024 (edited) You are correct you have to close the dcl and reopen it. the key is distance so (set_tile "distance" dist) the dist would be the object length as a string maybe need to check, when you start dcl the dist (if (= dist nil) (setq dist "0") (setq dist (rtos len 2 2)) ) ) (set_tile "distance" dist) (action_tile "select_btn" "(done_dialog 2)") Edited October 23, 2024 by BIGAL Quote
Stefan BMR Posted October 24, 2024 Posted October 24, 2024 Hi Use a while loop to re-open the dialog if "Select" button is picked. Like this (defun c:OpenDCLDialog ( / dcl_id dclflag dst) (setq dclflag 2) (if (and (setq dcl_id (load_dialog "example_dialog.dcl")) (> dcl_id 0) ) (progn (while (> dclflag 1) (new_dialog "example_dialog" dcl_id) (if dst (set_tile "distance" dst)) (action_tile "distance" "(setq dst $value)") (action_tile "select_btn" "(done_dialog 2)") (action_tile "ok_btn" "(done_dialog 1)") (setq dclflag (start_dialog)) (if (and (= dclflag 2) (setq dst (:select)) ) (setq dst (rtos dst)) ) );while (unload_dialog dcl_id) (if (= dclflag 1) (distof dst) ) );progn ) ) (defun :select () (setq entity (car (entsel "\nSelect an entity: "))) (setq ponto (assoc 10 (entget entity))) (setq dist (getdist (cdr ponto) "Distance: ")) ;;vou fazer algo aqui ) 1 Quote
Anushka Posted October 24, 2024 Author Posted October 24, 2024 @Stefan BMR Thank you, that's what I needed. Quote
