renzzzo Posted October 23, 2024 Posted October 23, 2024 I hope someone could help me with a little lisp routine. I'm looking to improve layiso command for my needs. I would like to select some objects on some layers and isolate those layers (so far so good)... and in the same time select a xref and a block and isolate all unfrozen layers in those as well. Layiso command only isolates layers that block and xref are on. I would like to autoselect all block-xref entities and isolate those layers. Quote
Emmanuel Delay Posted October 23, 2024 Posted October 23, 2024 (edited) Yeah, sure. With NENTSEL you van select nested items: for example items inside a XREF or Block. Here's a function that turns off layers of selected nested items. Command LOFF, for Layers OFF Command NLAYISO for the question you asked for ;; @see https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/turning-off-layers-in-autolisp/td-p/6339611 (DEFUN LAYER_OFF (mylayer on_off / Layoff ) ;;(setq Layoff(getstring "\Should the Layer C165-C345-EBENE turned off? (j/n): ")) (setq Layoff "Y") (if (or (= Layoff "j") (= Layoff "J") (= Layoff "y") (= Layoff "Y")) (if (/= (tblsearch "layer" mylayer) nil) ;;(command "_layer" "_off" mylayer "") (command "_layer" on_off mylayer "") ;;(princ mylayer) );IF );IF );DEFUN LAYER_OFF ;; Turns off layers of NENTSEL selection, of the layer of nested objects (defun c:loff ( / sel obj lay lst) (while (setq sel (nentsel "Select object: ")) (setq obj (car sel)) (setq lay (cdr (assoc 8 (entget obj)))) (LAYER_OFF lay "_off") ) ) ;; nLayiso for Nested Layiso (defun c:nLayiso ( / blk sel obj lay lst) (setq lst (list)) (while (setq sel (nentsel "\nSelect object: ")) (setq obj (car sel)) (setq lay (cdr (assoc 8 (entget obj)))) (setq lst (append lst (list lay))) (princ lay) ) ;; loop over all layers in the drawing (vlax-for lyr (vla-get-layers (vla-get-activedocument (vlax-get-acad-object) ) ) (setq lay (vla-get-name lyr)) ;; exclude current layer (if (/= lay (getvar "CLAYER")) ;; IF layer is in lst then turn on, else turn off (if (member lay lst) (LAYER_OFF lay "_on") (LAYER_OFF lay "_off") ) ) ) ) Happy with this? Edited October 23, 2024 by Emmanuel Delay 2 Quote
renzzzo Posted October 23, 2024 Author Posted October 23, 2024 (edited) Managed to achieve what I was after using chatgpt-s help: (defun c:isolay (/ ss lay layers-to-keep lay-name i doc layer first-layer) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (setq ss (ssget)) (if ss (progn (setq layers-to-keep '()) (setq first-layer (vla-get-layer (vlax-ename->vla-object (ssname ss 0)))) (setq i 0) (repeat (sslength ss) (setq lay-name (vla-get-layer (vlax-ename->vla-object (ssname ss i)))) (if (not (member lay-name layers-to-keep)) (setq layers-to-keep (cons lay-name layers-to-keep)) ) (setq i (1+ i)) ) (setq first-layer (vla-item (vla-get-layers doc) first-layer)) (if (and first-layer (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-get-name (list first-layer))))) (vla-put-activelayer doc first-layer) ) (vlax-for layer (vla-get-layers doc) (setq lay-name (vla-get-name layer)) (if (and (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-get-name (list layer)))) (not (equal lay-name (vla-get-name first-layer))) (not (vl-string-search "|" lay-name))) (vla-put-freeze layer :vlax-true) ) ) (foreach lay layers-to-keep (setq layer (vla-item (vla-get-layers doc) lay)) (if (and layer (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-get-name (list layer))))) (if (and (vla-get-freeze layer) (not (equal lay (vla-get-name first-layer)))) (vla-put-freeze layer :vlax-false) ) (vla-put-lock layer :vlax-false) ) ) ) ) (princ) ) Edited October 24, 2024 by SLW210 Added Code Tags!! Quote
SLW210 Posted October 24, 2024 Posted October 24, 2024 Please use Code tags for your code, not Quote Tags. (<> in the editor toolbar) Quote
