Help to change the LeeMac autolisp file: "AreaLabel.lsp"
Hello, first of all I don't know anything about autolisp, I would like to know if it is possible to modify LeeMac's wonderful Arealabel lisp so that in addition to what it already does, it generates shading for the Areas and a perimeter mainly, and if it also creates a new layer for each of those shadings that would be great, in my case it would help me if the shading was solid and if it were possible for the layers to have the same name as the Area. I would like the perimeter to always be in a specific layer but that is not a priority. Could someone help me? The lisp for those who don't know it is the following:
;;---------------------=={ Area Label }==---------------------;;
;;  Allows the user to label picked areas or objects and      ;;
;;  either display the area in an ACAD Table (if available),  ;;
;;  optionally using fields to link area numbers and objects; ;;
;;  or write it to file.                                      ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Version 1.9    -    29-10-2011                            ;;
(defun c:AT nil (AreaLabel   t))  ;; Areas to Table
(defun c:AF nil (AreaLabel nil))  ;; Areas to File
(defun AreaLabel ( flag / *error* _startundo _endundo _centroid _text _open _select _getobjectid _isannotative
                          acdoc acspc ap ar as cf cm el fd fl fo n of om p1 pf pt sf st t1 t2 tb th ts tx ucsxang ucszdir )
  ;;                         Adjustments                        ;;
  (setq h1 "Tabla Areas"  ;; Heading
        t1 "Numero"      ;; Number Title
        t2 "Area"        ;; Area Title
        pf "Finca_"            ;; Number Prefix (optional, "" if none)
        sf ""            ;; Number Suffix (optional, "" if none)
        ap ""            ;; Area Prefix (optional, "" if none)
        as "m²"            ;; Area Suffix (optional, "" if none)
        cf 1.0           ;; Area Conversion Factor (e.g. 1e-6 = mm2->m2)
        fd t             ;; Use fields to link numbers/objects to table (t=yes, nil=no)
        fo "%lu6%qf1"    ;; Area field formatting
  (defun *error* ( msg )
    (if cm (setvar 'CMDECHO cm))
    (if el (progn (entdel el) (setq el nil)))
    (if acdoc (_EndUndo acdoc))
    (if (and of (eq 'FILE (type of))) (close of))
    (if (and Shell (not (vlax-object-released-p Shell))) (vlax-release-object Shell))
    (if (null (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
        (princ (strcat "\n--> Error: " msg))
  (defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
  (defun _EndUndo ( doc )
    (if (= 8 (logand 8 (getvar 'UNDOCTL)))
      (vla-EndUndoMark doc)
  (defun _centroid ( space objs / reg cen )
    (setq reg (car (vlax-invoke space 'addregion objs))
          cen (vlax-get reg 'centroid)
    (vla-delete reg) (trans cen 1 0)
  (defun _text ( space point string height rotation / text )
    (setq text (vla-addtext space string (vlax-3D-point point) height))
    (vla-put-alignment text acalignmentmiddlecenter)
    (vla-put-textalignmentpoint text (vlax-3D-point point))
    (vla-put-rotation text rotation)
    text
  (defun _Open ( target / Shell result )
    (if (setq Shell (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
        (setq result
          (and (or (eq 'INT (type target)) (setq target (findfile target)))
            (not
              (vl-catch-all-error-p
                (vl-catch-all-apply 'vlax-invoke (list Shell 'Open target))
    result
  (defun _Select ( msg pred func init / e ) (setq pred (eval pred))
    (while
      (progn (setvar 'ERRNO 0) (apply 'initget init) (setq e (func msg))
        (cond
          ( (= 7 (getvar 'ERRNO))
            (princ "\nMissed, try again.")
          ( (eq 'STR (type e))
            nil
          ( (vl-consp e)
            (if (and pred (not (pred (setq e (car e)))))
              (princ "\nInvalid Object Selected.")
    e
  (defun _GetObjectID ( doc obj )
    (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
      (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false)
      (itoa (vla-get-Objectid obj))
  (defun _isAnnotative ( style / object annotx )
    (and
      (setq object (tblobjname "STYLE" style))
      (setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative")))))
      (= 1 (cdr (assoc 1070 (reverse annotx))))
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
        acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
        ucszdir (trans '(0. 0. 1.) 1 0 t)
        ucsxang (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 ucszdir))
  (_StartUndo acdoc)
  (setq cm (getvar 'CMDECHO))
  (setvar 'CMDECHO 0)
  (setq om (eq "1" (cond ((getenv "LMAC_AreaLabel")) ((setenv "LMAC_AreaLabel" "0")))))
  (setq ts
    (/ (getvar 'TEXTSIZE)
      (if (_isAnnotative (getvar 'TEXTSTYLE))
        (cond ( (getvar 'CANNOSCALEVALUE) ) ( 1.0 )) 1.0
  (cond
    ( (not (vlax-method-applicable-p acspc 'addtable))
      (princ "\n--> Table Objects not Available in this Version.")
    ( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER))))))
      (princ "\n--> Current Layer Locked.")
    ( (not
        (setq *al:num
          (cond
              (getint
                (strcat "\nSpecify Starting Number <"
                  (itoa (setq *al:num (1+ (cond ( *al:num ) ( 0 ))))) ">: "
            ( *al:num )
    ( flag
      (setq th
        (* 2.
          (if
            (zerop
              (setq th
                (vla-gettextheight
                  (setq st
                    (vla-item
                      (vla-item
                        (vla-get-dictionaries acdoc) "ACAD_TABLESTYLE"
                      (getvar 'CTABLESTYLE)
                  acdatarow
            ts
            (/ th
              (if (_isAnnotative (vla-gettextstyle st acdatarow))
      (if
        (cond
            (progn (initget "Add")
              (vl-consp (setq pt (getpoint "\nPick Point for Table <Add to Existing>: ")))
            (setq tb
              (vla-addtable acspc
                (vlax-3D-point (trans pt 1 0)) 2 2 th (* 0.8 th (max (strlen t1) (strlen t2)))
            (vla-put-direction tb (vlax-3D-point (getvar 'UCSXDIR)))
            (vla-settext tb 0 0 h1)
            (vla-settext tb 1 0 t1)
            (vla-settext tb 1 1 t2)
            (while
                (if om
                  (setq p1
                    (_Select (strcat "\nSelect Object [Pick] <Exit>: ")
                     '(lambda ( x )
                        (and
                          (vlax-property-available-p (vlax-ename->vla-object x) 'area)
                          (not (eq "HATCH" (cdr (assoc 0 (entget x)))))
                          (or (eq "REGION" (cdr (assoc 0 (entget x)))) (vlax-curve-isclosed x))
                      entsel '("Pick")
                  (progn (initget "Object") (setq p1 (getpoint "\nPick Area [Object] <Exit>: ")))
                (cond
                  ( (null p1)
                    (vla-delete tb)
                  ( (eq "Pick" p1)
                    (setq om nil) t
                  ( (eq "Object" p1)
                    (setq om t)
                  ( (eq 'ENAME (type p1))
                    (setq tx
                      (cons
                        (_text acspc
                          (_centroid acspc (list (setq p1 (vlax-ename->vla-object p1))))
                          (strcat pf (itoa *al:num) sf)
                          ts
                          ucsxang
                        tx
                    (vla-insertrows tb (setq n 2) th 1)
                    (vla-settext tb n 1
                      (if fd
                        (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                          (_GetObjectID acdoc p1) ">%).Area \\f \"" fo "\">%"
                        (strcat ap (rtos (* cf (vla-get-area p1)) 2) as)
                    (vla-settext tb n 0
                      (if fd
                          (_GetObjectID acdoc (car tx)) ">%).TextString>%"
                    nil
                  ( (vl-consp p1)
                    (setq el (entlast))
                    (vl-cmdf "_.-boundary" "_A" "_I" "_N" "" "_O" "_P" "" "_non" p1 "")
                    (if (not (equal el (setq el (entlast))))
                        (setq tx
                          (cons
                            (_text acspc
                              (_centroid acspc (list (vlax-ename->vla-object el)))
                              ts
                              ucsxang
                            tx
                        (vla-settext tb n 1 (strcat ap (rtos (* cf (vlax-curve-getarea el)) 2) as))
                        (vla-settext tb n 0
                          (if fd
                        (redraw el 3)
                        nil
                      (vla-delete tb)
            (not (vlax-erased-p tb))
            (and
              (setq tb
                (_Select "\nSelect Table to Add to: "
                 '(lambda ( x ) (eq "ACAD_TABLE" (cdr (assoc 0 (entget x))))) entsel nil
              (< 1 (vla-get-columns (setq tb (vlax-ename->vla-object tb))))
            (setq n (1- (vla-get-rows tb)) *al:num (1- *al:num))
          (while
            (if om
              (setq p1
                (_Select (strcat "\nSelect Object [" (if tx "Undo/" "") "Pick] <Exit>: ")
                 '(lambda ( x )
                    (and
                  entsel (list (if tx "Undo Pick" "Pick"))
              (progn (initget (if tx "Undo Object" "Object"))
                (setq p1 (getpoint (strcat "\nPick Area [" (if tx "Undo/" "") "Object] <Exit>: ")))
            (cond
              ( (and tx (eq "Undo" p1))
                (vla-deleterows tb n 1)
                (vla-delete (car tx))
                (setq n (1- n) tx (cdr tx) *al:num (1- *al:num))
              ( (eq "Undo" p1)
                (princ "\n--> Nothing to Undo.")
              ( (eq "Object" p1)
                (setq om t)
              ( (eq "Pick" p1)
                (setq om nil)
              ( (and om (eq 'ENAME (type p1)))
                (setq tx
                  (cons
                    (_text acspc
                      (strcat pf (itoa (setq *al:num (1+ *al:num))) sf)
                      ts
                      ucsxang
                    tx
                (vla-insertrows tb (setq n (1+ n)) th 1)
                (vla-settext tb n 1
                  (if fd
                (vla-settext tb n 0
                  (if fd
              ( (vl-consp p1)
                (setq el (entlast))
                    (setq tx
                      (cons
                        (_text acspc
                          ts
                          ucsxang
                        tx
                    (vla-settext tb n 0
                      (if fd
                    (redraw el 3)
                  (princ "\n--> Error Retrieving Area.")
      (and
        (setq fl (getfiled "Create Output File" (cond ( *file* ) ( "" )) "txt;csv;xls" 1))
        (setq of (open fl "w"))
      (setq *file*  (vl-filename-directory fl)
            de      (cdr (assoc (strcase (vl-filename-extension fl) t) '((".txt" . "\t") (".csv" . ",") (".xls" . "\t"))))
      (write-line h1 of)
      (write-line (strcat t1 de t2) of)
      (while
        (if om
          (setq p1
             '(lambda ( x )
                (and
              entsel '("Pick")
          (progn (initget "Object") (setq p1 (getpoint (strcat "\nPick Area [Object] <Exit>: "))))
        (cond
          ( (eq "Object" p1)
            (setq om t)
          ( (eq "Pick" p1)
            (setq om nil)
            (_text acspc
              ts
              ucsxang
            (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vla-get-area p1)) 2) as) of)
          ( (vl-consp p1)
            (setq el (entlast))
                (_text acspc
                  ts
                  ucsxang
                (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vlax-curve-getarea el)) 2) as) of)
                (redraw el 3)
      (setq of (close of))
      (_Open (findfile fl))
  (setenv "LMAC_AreaLabel" (if om "1" "0"))
  (_EndUndo acdoc)
(vl-load-com)
(princ "\n:: AreaLabel.lsp | Version 1.9 | © Lee Mac 2011 www.lee-mac.com ::")
(princ "\n:: Commands: \"AT\" for ACAD Table, \"AF\" for File ::")
;;                         End of File                        ;;
Edited by Hecsus
"if it is possible to modify LeeMac's wonderful Arealabel lisp "
The answer is yes but it is always best to ask the author first about possible changes to his or her code as a sign of respect, Lee has a contact me on his website and he often responds here.
The Bpoly command will make a boundary for the area, you can then use this to hatch the area with a solid pattern.
  • Like 2
Hi,
First of all, thank you very much for answering. I didn't want to offend anyone, and even less someone who knows so much about the subject. Seeing other similar requests here, I thought there would be no problem.
Back to this, as I said, I don't know anything about Autolisp. The little I know doesn't allow me to change the code with "bpoly". I'll try to ask LeeMac, I hope he can answer me and help me ^^
