Nicky Posted 10 hours ago Share Posted 10 hours ago Hello everyone, I have a small problem with the code below: The routine allows by choosing an altitude multiple (0.5/1/2/5/10/25/50/100 meters) to place in a (new) layer the contour lines (located in an original layer) meeting the criterion. However, recently, some curves are not placed in the new layer while the criterion is respected (the altitudes displayed in the properties are correct). There may be an error in the code, or a variable to modify (precision or close rounding for example..)? Thank you, (defun c:MAJCL ( ;/ elev ss i el ) (vl-load-com) (setq Valer (getvar "luprec")) (setvar "luprec" 0) (initget 1 "0.5 1 2 5 10 25 50 100") (setq elev (getkword "\nSelect String for filter [0.5/1/2/5/10/25/50/100]: " ) ) (setq LayerCL (car (entsel "\nClick on a layer with contour lines to modify : " ) ) ) (setq EntLay (entget LayerCL)) (setq LAY (cdr (assoc 8 EntLay))) (setq nomcalc (strcat "_NB-MajorLine_" elev)) (initget 1 "Blue Green GRey Pink Red White Yellow Other") (setq ColorCalc (getkword "\nSelect a color for the layer [Blue/Green/GRey/Pink/Red/White/Yellow/Other]: " ) ) (cond ((= ColorCalc "Blue") (setq Color 141) ) ((= ColorCalc "Green") (setq Color 91) ) ((= ColorCalc "GRey") (setq Color 253) ) ((= ColorCalc "Pink") (setq Color 211) ) ((= ColorCalc "Red") (setq Color 241) ) ((= ColorCalc "White") (setq Color 7) ) ((= ColorCalc "Yellow") (setq Color 51) ) ((= ColorCalc "Other") (setq Color 121) ) ) (if (not (tblsearch "LAYER" nomcalc)) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 nomcalc) (cons 70 0) (cons 62 Color) (cons 370 -3) (cons 6 "Continuous") ) ) ) (if (setq ss (ssget "_X" (list (cons 0 "LWPOLYLINE") (cons 8 LAY)) ) ) (repeat (setq i (sslength ss)) (setq el (cdr (assoc 38 (entget (setq e (ssname ss (setq i (1- i)))))) ) ) (if (equal (distof (rtos (rem el (distof elev)) 2 2)) 0.0 1e-6) ; at elevation that is a multiple of elev? (vla-put-Layer (vlax-ename->vla-object e) nomcalc) ;(command "_.chprop" e "" "_layer" nomcalc "") ) ; if ) ; repeat ) ; if (setvar "luprec" Valer) (princ) ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted 6 hours ago Share Posted 6 hours ago Have you got an example drawing where this isnt working? Quote Link to comment Share on other sites More sharing options...
Nicky Posted 4 hours ago Author Share Posted 4 hours ago (edited) HI Steven, Of course. Here is an example. In this example 1, 5 and 25 feet does not work perfectly. One more thing you should know: Usually the files come from another application (Mensura) and are in meters. I transform them into feet using another scaling routine below... (defun c:SCFTM () (command "insunits" 6) (command "_units" 2 3 1 1 0 "N") (setq selec (ssget "_X")) (command "-dwgunits" 2 2 4 "yes" "no" "yes" "no") ;;(command "_.scale" selec "" '(0 0 0) 1000) (command "_.zoom" "e") ;; (command "_units" 2 3 1 1 0 "N") (command "insunits" 2) ) Thanks. Crooked Mile export mensura test.dwg Edited 4 hours ago by Nicky Quote Link to comment Share on other sites More sharing options...
BIGAL Posted 1 hour ago Share Posted 1 hour ago The obvious for me. (setq elev (/ (* 9.164 1000.0) 0.3048)) = 30065.6167979003 With regard to round up/down do you want for say 0.5, 30065.499999 = 30065.5 or 30065.0 or 30066.0 ie round up or down. Quote Link to comment Share on other sites More sharing options...
Tsuky Posted 1 hour ago Share Posted 1 hour ago For try, this exemple? (defun c:foo ( / ss l c n dxf_ent elev) (setq ss (ssget "_X" '((0 . "LWPOLYLINE") (8 . "Terrain - Cont. - Contours")))) (cond (ss (setq l '(0.5 1.0 2.0 5.0 10.0 25.0 50.0 100.0) c '(8 7 6 5 4 3 2 1) ) (repeat (setq n (sslength ss)) (setq dxf_ent (entget (ssname ss (setq n (1- n)))) elev (read (rtos (cdr (assoc 38 dxf_ent)) 2 1)) ) (mapcar '(lambda (x) (if (and (zerop (rem elev (car x))) (null (assoc 62 dxf_ent))) (progn (setq dxf_ent (subst (cons 8 (strcat "_NB-MajorLine_" (if (eq (car x) (fix (car x))) (rtos (car x) 2 0) (rtos (car x) 2 1)))) (assoc 8 dxf_ent) dxf_ent ) ) (entmod (append dxf_ent (list (cons 62 (cdr x))))) ) ) ) (mapcar 'cons l c) ) ) ) ) ) Quote Link to comment Share on other sites More sharing options...
