Help to change the LeeMac autolisp file: "DimensionOverlapV1-2.lsp"
I would need to make a change to the LeeMac autolisp file "DimensionOverlapV1-2.lsp":
If I running this lisp, the ENTIRE drawing is verified, which takes a long time. Since I often print only parts of a drawing, I wish I could only check the overlapping dimensions in a little area: by giving the vertices of the rectangle pt1 and pt2.
I could then add this command to the print command in order to warn me if there are overlapping dimensions and thus be able to stop printing.
Thank you very much.
I like this idea - I'll look to update my program to incorporate an optional selection prompt if I get a chance.
Lee Mac accepting my suggestion is a great honor for me!
Something to brag about with friends! 😜
Joking aside, I'm very happy: thank you very much!
I would like to point out that selecting only a part of the drawing does NOT verify the dimensions within the blocks... which instead happens by having the whole design processed.
