X11start Posted October 21, 2024 Posted October 21, 2024 I would need to make a change to the LeeMac autolisp file "DimensionOverlapV1-2.lsp": If I running this lisp, the ENTIRE drawing is verified, which takes a long time. Since I often print only parts of a drawing, I wish I could only check the overlapping dimensions in a little area: by giving the vertices of the rectangle pt1 and pt2. I could then add this command to the print command in order to warn me if there are overlapping dimensions and thus be able to stop printing. Thank you very much. Quote
Lee Mac Posted October 21, 2024 Posted October 21, 2024 I like this idea - I'll look to update my program to incorporate an optional selection prompt if I get a chance. Quote
Lee Mac Posted October 21, 2024 Posted October 21, 2024 I've now updated my Dimension Overlap program to version 1.3 to incorporate a selection prompt. 2 Quote
X11start Posted October 22, 2024 Author Posted October 22, 2024 Lee Mac accepting my suggestion is a great honor for me! Something to brag about with friends! Joking aside, I'm very happy: thank you very much! Quote
X11start Posted October 25, 2024 Author Posted October 25, 2024 I would like to point out that selecting only a part of the drawing does NOT verify the dimensions within the blocks... which instead happens by having the whole design processed. Quote
