I have a filter in a lisp file that is made by RLX. I want to understand it better so i can modify the filter for more use.
I use this filter for blocknames.
This exaMple works very well. The problem is when i want to filter the begin of a blockname with the end of the same blockname.
The result at the second filter is DIN934-A0M04IN - >This has to be DIN934-A0M04SD or ED.
What can i do to get the result i want? If someone can explane the filter where i start this topic with, thank you.
DIN934MODIFYDO.LSPFetching info...
Edited by patjeacad
Added Code Tags!
Please use code tags for code! (<> in the editor toolbar)
Expand
sorry, i did now.
A ssget with correct block filter should work.
(setq ss (ssget (list (cons 0 "INSERT")(cons 2 "DIN934-A#M##*"))))
or a full filter
(setq ss (ssget (list (cons 0 "INSERT")(cons 2 "DIN934-A#M##ED,DIN934-A#M##SD"))))
