Hi all,
I am having some issues with a PLOT function.
when a PDF is in use by 'somebody' and i want to overwrite it, i cannot seem to detect the 'lock' on the file.
this causes my program to crash.
Is there a way to check if a PDF is in use/can be overwritten?
I think this is it:
Result is Yes, No or New, 'Yes' PDF is currently open, 'No', it exists and is closed, 'New' PDF file doesn't exist
(defun PDFOpened( PDFFilename / PDFO)
  (if (findfile PDFFilename) ;; Full file path & name
      (if (vl-file-rename PDFFilename PDFFilename)
        (setq PDFO "No")  ;;file is closed
        (setq PDFO "Yes") ;;file is open
      ) ; end if
    ) ; end progn
      (setq PDFO "New")
    ) ; end progn
  ) ; end of
  PDFO
Edited by Steven P
@Steven P
The code gave me some odd behaviour due to this:
Note: If the target file already exists, this function fails.
Managed to solve it with this function for now:
(defun is-file-locked (file-path)
  (setq file (open file-path "w")) ; Try to open the file in write mode
  (if file
      (close file) ; If successful, close the file
      nil) ; Not locked
    t) ; If failed, it is locked
Ahh, i missed a closing ) - edited above and it should work now
