Lucas11 Posted Friday at 11:03 PM Share Posted Friday at 11:03 PM (edited) Background: I have a dwg with multiple sheets (each layout tab is another sheet). In in a wiring diagram, some wires go off page, and so I have to show the page number the wire is jumping to. Let's say I have a Rectangle A and a Rectangle B and a wire (line) that I want to show is connecting the two rectangles. However, Rectangle A is on sheet 1 (Layout tab 1) and Rectangle B is on sheet 2 (Layout tab 2). And so I would draw a line from Rectangle 1 but then at the end of the line, I put the sheet number (layout tab number) that Rectangle B is located on. I would do the same for Rectangle B and at the end of its line show the sheet number (layout tab number) that Rectangle A is located on. Problem: I would like to move Rectangle B to another sheet, say sheet 3 (Layout tab 3), and the reference to Rectangle B that's on sheet 1 would automatically update from sheet 2 to sheet 3, or whatever sheet number I move Rectangle B to. Is it possible to have the sheet number reference automatically update to the sheet number where the referenced Rectangle is located? EXAMPLE.dwg Edited Friday at 11:05 PM by Lucas11 Attaching dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted Sunday at 10:41 PM Share Posted Sunday at 10:41 PM Just a comment I have looked at this a few times thinking about how to do. In a grid style of sheets can have up to 4 sheets touching. One possible way is using fields that you would get a A B C etc from a sheet and put that into the description of connection. So would have "A" Rather than "Sheet 1". So manually can be done. Or have "A" on a non plot layer. Try this a very simple make a field from one text and put answer in another. ; make a field from one text and put answer in another. ; By Alan H Oct 2024 (defun c:wow ( / obj1 obj2 str txt) (setq obj1 (vlax-ename->vla-object (car (entsel "\nPick source text ")))) (setq obj2 (vlax-ename->vla-object (car (entsel "\nPick destination text ")))) (setq id (vlax-invoke-method (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object))) 'GetObjectIdString obj1 :vlax-false)) (setq str (strcat "%<\\AcObjProp Object(%<\\_ObjId " id ">%).TextString>%")) (vlax-put obj2 'textstring str) (princ) ) Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted 4 hours ago Share Posted 4 hours ago If you use sheet sets, you can assign a sheet number (or a custom property) to a field. Whenever the sheet number changes, all the fields that reference it will change as well. Will that do what you want? Or are sheet sets not an option? Quote Link to comment Share on other sites More sharing options...
