ILoveMadoka Posted 11 hours ago Share Posted 11 hours ago Given a drawing with multiple tables/table styles on multiple layouts and an existing layer named MYLAYER. This line (setq ss (ssget "x" '((0 . "ACAD_TABLE")))) Places ALL Autocad Tables on ALL Layouts into one selection set [ ss ] If I manually go to any layout and enter this code (command "change" ss "" "p" "la" "MyLayer" "") It changes all the tables on that layout to MYLAYER. The following code works on the first layout but does not work for others. (defun C:foo () (setq ss (ssget "x" '((0 . "ACAD_TABLE")))) (foreach lay (layoutlist) (setvar 'ctab lay) (command "change" ss "" "p" "la" "MyLayer" "") ); foreach ); defun this code (defun C:foo () (foreach lay (layoutlist) (setvar 'ctab lay) (command "line" "0,0" "30,20" "") ); foreach ); defun and this code (defun C:Foo () (setq ss (ssget "x" '((0 . "ACAD_TABLE")))) (foreach lay (layoutlist) (setvar 'ctab lay) (command "line" "0,0" "30,20" "") ); foreach ); defun Work on all layouts of the same drawing. Anyone have any idea why the first routine would not work on ALL layouts of a specific drawing? I cannot upload the drawing without losing my job. Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted 11 hours ago Author Share Posted 11 hours ago Can the all tables on all layouts be moved to a different pre-existing layer without changing to the different layouts? Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted 11 hours ago Share Posted 11 hours ago This should work as desired... (defun c:foo ( / *error* cmd pck ss sss ) (defun *error* ( m ) (if (= 8 (logand 8 (getvar (quote undoctl)))) (if command-s (command-s "_.undo" "_e") (vl-cmdf "_.undo" "_e") ) ) (if pck (setvar (quote pickfirst) pck) ) (if cmd (setvar (quote cmdecho) cmd) ) (if m (prompt m) ) (princ) ) (setq cmd (getvar (quote cmdecho))) (setvar (quote cmdecho) 0) (setq pck (getvar (quote pickfirst))) (setvar (quote pickfirst) 1) (if (= 8 (logand 8 (getvar (quote undoctl)))) (vl-cmdf "_.undo" "_e") ) (vl-cmdf "_.undo" "_be") (if (setq ss (ssget "_X" (list (cons 0 "ACAD_TABLE")))) (foreach lay (append (list "Model") (layoutlist)) (setvar (quote ctab) lay) (sssetfirst nil ss) (setq sss (ssget "_:L-I")) (if (tblsearch "layer" "MyLayer") (vl-cmdf "_.change" sss "" "_p" "_la" "MyLayer" ""); then (progn (vl-cmdf "_.-layer" "_m" "MyLayer") (while (< 0 (getvar (quote cmdactive))) (vl-cmdf "") ) (vl-cmdf "_.change" sss "" "_p" "_la" "MyLayer" "") ); else ); if ); foreach ); if (setvar (quote clayer) "0") (setvar (quote ctab) "Model") (*error* nil) ); defun HTH. Regards, M.R. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted 9 hours ago Share Posted 9 hours ago (edited) In your original code, the initial selection set contains all tables in the drawing database, hence, supplying this selection set to the command when each layout is active may result in the selection being empty if that layout does not contain a table, or if all tables reside in other layouts/spaces. Instead, it is better to acquire the selection set for each layout and check its existence prior to calling the command, e.g.: (defun c:foo ( / ctb sel ) (setq ctb (getvar 'ctab)) (foreach lyt (layoutlist) (setvar 'ctab lyt) (if (setq sel (ssget "_X" (list '(0 . "ACAD_TABLE") (cons 410 lyt)))) (command "_.change" sel "" "_p" "_la" "MyLayer" "") ) ) (setvar 'ctab ctb) (princ) ) (Assuming the layer already exists) Edited 5 hours ago by Lee Mac Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted 9 hours ago Share Posted 9 hours ago Of course, alternatively, no layout switching is required if you forego the command call: (defun c:foo ( / ent idx sel ) (if (setq sel (ssget "_X" '((0 . "ACAD_TABLE")))) (repeat (setq idx (sslength sel)) (setq idx (1- idx) enx (entget (ssname sel idx)) ) (entmod (subst '(8 . "MyLayer") (assoc 8 enx) enx)) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted 9 hours ago Author Share Posted 9 hours ago Lee Mac to the rescue (Once again!) "Here I come to save the day...!" <marko_ribar> Thank you for the reply. On the drawing that I cannot upload your code works on the very first layout like mine. Lee, thank you so very much Sir!! Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted 9 hours ago Author Share Posted 9 hours ago Lee... Change your avatar to Mighty Mouse 1 Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted 9 hours ago Author Share Posted 9 hours ago Quote forego the command call: Man! That is SO MUCH faster!! Thank you even more! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted 5 hours ago Share Posted 5 hours ago You're welcome! Quote Link to comment Share on other sites More sharing options...
