Good day to all!
How to replace only the numbers at the end in the text (mtext).
Select multiple texts and replace the numbers with the same number.
Is there a lisp that allows you to replace only numbers in selected texts?
For example:
Text 1
Text text 1
Text text text 1
MLeader 1
Replace with:
Text 34
Text text 34
Text text text 34
MLeader 34
Is it possible to add MLeaders to the selection?
Thank you in advance...
Replace numbers.dwgFetching info...
Edited by Nikon
CAN YOU USE THIS
https://www.lee-mac.com/parsenumbers.html
;; Parse Numbers  -  Lee Mac
;; Parses a list of numerical values from a supplied string.
(defun LM:parsenumbers ( str )
    (   (lambda ( l )
            (read
                (strcat "("
                    (vl-list->string
                        (mapcar
                           '(lambda ( a b c )
                                (if (or (< 47 b 58)
                                        (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                                        (and (= 46 b) (< 47 a 58) (< 47 c 58))
                                    b 32
                            (cons nil l) l (append (cdr l) '(()))
        (vl-string->list str)
Nikon
Those are bad examples.
What do you want when it's something defferent from a 1?
What about two ones?
What about two numbers on different places?
"Text 1text 1"
"T3322223333665589657ext text"
"Tex44t text text9000"
What do you expect there?
  On 10/16/2024 at 12:42 PM, Emmanuel Delay said:
"Text 1text 1"
Expand
I have text (or MLeader) with the same numbers at the end (1 or 12 or 33...)
I need to replace all the same numbers with other same ones... see the attached .dwg
The numbers are only at the end
Edited by Nikon
With your exemple seem to do the job.
(defun extractNumbers (str / l rslt)
  (setq
    l
    (mapcar
      '(lambda (x)
        (if (and (> x 44) (< x 58) (/= x 47)) x 32)
    l
    (mapcar
      '(lambda (x y)
        (if (not (= x y 32)) x)
      l
      (append (cdr l) '(32))
    l (vl-remove-if-not '(lambda (x) (eq (type x) 'INT) x) l)
    l (mapcar '(lambda (x) (if (not (eq x 32)) x (list nil))) l)
  (eval (read (strcat "(setq rslt (list " (apply 'strcat (mapcar '(lambda (x) (if (not (listp x)) (chr x) " ")) l)) "))")))
(defun c:replacenumber ( / ss nb n ename dxf_ent txt old_num old_list)
  (setq ss (ssget '((0 . "*TEXT"))))
  (cond
    (ss
      (initget 1)
      (setq
        nb (getint "\nEnter number to substitue: ")
        nb (vl-string->list (itoa nb))
      (repeat (setq n (sslength ss))
        (setq
          ename (ssname ss (setq n (1- n)))
          dxf_ent (entget ename)
          txt (cdr (assoc 1 dxf_ent))
        (setq
          old_num (vl-string->list (itoa (car (extractNumbers txt))))
          old_list (vl-string->list txt)
        (foreach e old_num (setq old_list (vl-remove e old_list)))
        (entmod (subst (cons 1 (vl-list->string (append old_list nb))) (assoc 1 dxf_ent) dxf_ent))
  (prin1)
Expand
@Tsuky Thanks a lot!
This code handles text and mtext well.
Is it possible to add MLeader and attributes?
I have similar designs that I copy, modify and change the names with numbers.
I changed 30-40 titles one by one, I caught myself at number 35 and asked for help,
I will need to change 100 or more numbers.
You have helped me a lot!
  Quote
Expand
Tested briefly ....
(vl-load-com)
  (setq
    l
    (mapcar
      '(lambda (x)
    l
    (mapcar
      '(lambda (x y)
      l
(defun c:replacenumber ( / ss nb n ename txt rslt old_num old_list)
  (setq
    ss
    (ssget
      (list
        (cons 0 "*TEXT,MULTILEADER,INSERT")
        (cons 67 (if (eq (getvar "CVPORT") 2) 0 1))
        (cons 410 (if (eq (getvar "CVPORT") 2) "Model" (getvar "CTAB")))
  (cond
    (ss
      (initget 1)
      (setq
        (setq
          ename (vlax-ename->vla-object (cadar (ssnamex ss (setq n (1- n)))))
        (cond
          ((vlax-property-available-p ename 'TextString) (setq txt (vlax-get ename 'TextString))
            (cond
              ((eq (type (setq rslt (car (extractNumbers txt)))) 'INT)
                (setq
                  old_num (vl-string->list (itoa rslt))
                (vlax-put ename 'TextString (vl-list->string (append old_list nb)))
          (T
            (mapcar
              '(lambda (att)
                (setq txt (vlax-get-property att 'TextString))
                (cond
                    (setq
                    (vlax-put-property att 'TextString (vl-list->string (append old_list nb)))
              (vlax-invoke ename 'GetAttributes)
  (prin1)
Expand
@Tsuky Thanks for the quick reaction!
It works well with mleaders. But it doesn't work with attributes.
Please give me an example drawing so I can identify what is wrong.
Expand
I have attributes in a dynamic block, I will need to change the numbers in one of them
(maybe you need to specify an attribute tag to select?)
maybe it will be easier to write a separate code for attributes?
GRAPH_F.dwgUnavailable
Edited by Nikon
If it was me I'd use something like entsel to grab the text values, then use Lee Macs string to List with a delimitator of space ( " ") to split the string up into part, reverse the list and subs the new value into what is now the first item in the list. Reverse the list again, Lee Macs List to String, and pop that back into the text. Noting that uses a similar method.
For attribute blocks, VLA- functions to get and replace the text strings in the attributes rather than entsel
  • Thanks 1
Has anyone ever written a decent function that extracts all kinds of numeric values from a string?
for example "foo12.3e+6bar" should find 12.3E+6 (12.3 million)
What I would like is for the function either to return a list of the numbers along with position and length in the string.
Like "foo36bar12.4test" =>(list  (list 3 2 36) (list 8 4 12.4) )
Or return alternate string / number ... (list "foo" 36 "bar" 12.4 "test")
  On 10/17/2024 at 2:02 PM, Tsuky said:
This version ?
replacenumber.lsp
Expand
@Tsuky  very, very grateful!
This code performs the task wonderfully!
Now the work will go faster...
@BIGAL
Okay, I wrote something.
It seems to work.  It needs some cleanup no doubt
It's a way to extract numbers from a string.
@Nikon is your problem solved?
;; @FILE:
;; function  ENFS (for Extract Numbers From String) takes a string and returns a list of numbers in the string
;; the list is (list (list startPosition stringLength string) ... ) for each found number
;; substring, like php substr
(defun substring ( str idx len )
  (substr str (if (< idx 0) (+ 1 (strlen str) idx) (1+ idx)) len)
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/vba-method-quot-isnumeric-quot-lt-useing-in-vlisp/m-p/793105#M18763
(defun IsNumeric (string)
	(and
		(lastCharNumeric string)
		(distof string 2)
;; requires function substring
(defun lastCharNumeric (str / chrs)
	(setq chrs (vl-string->list str))
	(and
		(> (last chrs) 44) (< (last chrs) 58)
(defun c:ENFS ( / str)
	(setq str (getstring "\nString: " T))
	(princ
		(ENFS str)
;; ENFS for Extract Numbers From String
(defun ENFS (str /  i concat_num start numbers_data tent_num x         )
	(setq concat_num nil)
	(setq start 0)
	(setq numbers_data (list))
	(setq sure_num "")		;; last sure numeric string
	(setq tent_num "")		;; tentative number.  A string that
	(setq i 0)
	(foreach x (setq chrs (vl-string->list str))
		(if (or
				(and (> x 44) (< x 58)) 			;; 0 to 9
				(= x 43) (= x 45) (= x 46) (= x 101) (= x 69)				;; + - . e E      ;; characters that can possibly be part of a number.  For example 12.54e+6
			(progn							;; numerical
				(if  concat_num nil
						(setq start i)
						(setq concat_num T)
				(setq tent_num (substring str start  (+ 1 (- i start)) ) )
				(if (IsNumeric tent_num)
						(setq sure_num tent_num)
						;;(princ tent_num)
				;;(princ (chr x))
			;; else: not possibly a character that forms a number.
			;; so if this was not already done, we stop the number concatenation
				;;(princ "\n*")
		;; if it's the last character, we stop concatenating, so the last number gets added if it's at the end of the string
		(if (= i (- (strlen str) 1) )
		;; see if we must add the number to the list
		;; if tent_num
		(if (> (strlen sure_num) 0)
			(if concat_num
				T
				;; concatenating the number has ended, we will add the number to the list
					(setq numbers_data (append numbers_data (list
						(list i (strlen sure_num) sure_num)
					(setq sure_num "")
		(setq i (+ i 1))
	;;(princ "\n\n")
	;;(princ numbers_data)
	;; return list
	numbers_data
Edited by Emmanuel Delay
Expand
Thanks, the problem is solved. The code Tsuky (replacenumber.lsp) works perfectly.
