Ish Posted 19 hours ago Share Posted 19 hours ago If anyone have for above mentioned subject any lisp program please share . Either I select one by one or all at time . Export xy of mleader with text value in csv in sorting number . Thanks Cad file attached Thanks 0_MLEADER ARROW HEAD XY & TEXT VALUE.dwg Quote Link to comment Share on other sites More sharing options...
Saxlle Posted 15 hours ago Share Posted 15 hours ago Hi @Ish Try this: (defun c:EXMLD ( / save_location header op ss len i vals data pt pt_x pt_y ss2 data2 data3 val) (setq save_location (getfiled "Select a location for save" "" "csv" 1)) (setq header (strcat "TEXT" "," "EASTING" "," "NORTHING")) (setq op (open save_location "a")) (write-line header op) (setq ss (ssget "X" '((0 . "MULTILEADER")))) (setq len (sslength ss)) (setq i 0) (while (< i len) (setq vals nil) (setq data (entget (ssname ss i))) (setq pt (nth 56 data)) (setq pt_x (cadr pt)) (setq pt_y (caddr pt)) (command "._explode" (ssname ss i)) (setq ss2 (ssget "X" '((0 . "INSERT")))) (setq data2 (entget (ssname ss2 0))) (setq data3 (entget (entnext (cdr (assoc -1 data2))))) (setq val (cdr (assoc 1 data3))) (command "._undo" "1") (setq vals (strcat val "," (rtos pt_x 2 4) "," (rtos pt_y 2 4))) (write-line vals op) (setq i (1+ i)) ) (close op) (princ (strcat "\nThe data was saved in " "\"" (vl-filename-base save_location) "\"" ".")) (princ) ) To sort a list, after saving file, is much easier to do in excel using a "filter" above "Text" column. If this happen on picture 1, use the "Don't convert". Best regards. 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted 14 hours ago Author Share Posted 14 hours ago Thanks @Saxlle For sorting no issue for me It's working good but it not asking to select object, automatic internal select all and export. If possible for you please add select option one by one and select all. Thanks Quote Link to comment Share on other sites More sharing options...
Saxlle Posted 13 hours ago Share Posted 13 hours ago (edited) 22 minutes ago, Ish said: Thanks @Saxlle For sorting no issue for me It's working good but it not asking to select object, automatic internal select all and export. If possible for you please add select option one by one and select all. Thanks Your welcome @Ish. Try with this modification: (defun c:EXMLD ( / old_nomutt save_location header op answ ss len i vals data pt pt_x pt_y ss2 data2 data3 val) (setq old_nomutt (getvar "nomutt")) (setvar "nomutt" 1) (setq save_location (getfiled "Select a location for save" "" "csv" 1)) (setq header (strcat "TEXT" "," "EASTING" "," "NORTHING")) (setq op (open save_location "a")) (write-line header op) (initget "O A" 1) (setq answ (getkword "\nDo you want to select one by one or All? [O/A]:")) (if (= answ "O") (progn (princ "\nSelect multileaders:") (setq ss (ssget '((0 . "MULTILEADER")))) ) (progn (setq ss (ssget "X" '((0 . "MULTILEADER")))) ) ) (setq len (sslength ss)) (setq i 0) (while (< i len) (setq vals nil) (setq data (entget (ssname ss i))) (setq pt (nth 56 data)) (setq pt_x (cadr pt)) (setq pt_y (caddr pt)) (command "._explode" (ssname ss i)) (setq ss2 (ssget "X" '((0 . "INSERT")))) (setq data2 (entget (ssname ss2 0))) (setq data3 (entget (entnext (cdr (assoc -1 data2))))) (setq val (cdr (assoc 1 data3))) (command "._undo" "1") (setq vals (strcat val "," (rtos pt_x 2 4) "," (rtos pt_y 2 4))) (write-line vals op) (setq i (1+ i)) ) (close op) (setvar "nomutt" old_nomutt) (princ (strcat "\nThe data was saved in " "\"" (vl-filename-base save_location) "\"" ".")) (princ) ) Best regards. Edited 13 hours ago by Saxlle Quote Link to comment Share on other sites More sharing options...
BIGAL Posted 2 hours ago Share Posted 2 hours ago (edited) There is no problems using lisp for sorting a LIST I do up to 5 values in a list, so can sort on text only etc. Part 2 your welcome to use this just look inside it has all the functions you need to write direct to Excel. Just copy the function required from the code. Need a different app name for Libre Calc. Alan Excel library.lsp Edited 2 hours ago by BIGAL Quote Link to comment Share on other sites More sharing options...
