Lee Mac Posted April 5, 2009 Posted April 5, 2009 I have been trying to set a list of variables using mapcar, but can't seem to get them to hold the values. I am not sure why... I have tried: (defun c:test (/ vlst v1 v2 v3) (setq vlst (list v1 v2 v3)) (mapcar '(lambda (x y) (setq x y)) vlst '(1 2 3)) (princ)) to set the symbols "v1" "v2" & "v3" to 1, 2, 3 respectively, but this just keeps the variable "vlst" to (nil nil nil), and won't set them. Maybe I am having a stupid moment, or maybe there is a completely different function needed to accomplish this, but any ideas or opinions are welcomed. Cheers Lee Quote
jammie Posted April 5, 2009 Posted April 5, 2009 Hey Lee, I think the problem lies with declaring the symbols V1,V2 &V3 as variable names using SETQ. Using the function (setq x y) you are actually pass two arguments; X to create the variable and Y to assign it a value. In this instance I think SET would seem to be more appropiate From the acad support on SET The set function is similar to setq except that set evaluates both of its arguments whereas setq only evaluates its second argument Try the following (defun c:test (/ vlst) (setq vlst '(v1 v2 v3)) (mapcar '(lambda (x y) (set x y)) vlst '(1 2 3)) (princ)) Hope this is of some help, Jammie Quote
ASMI Posted April 5, 2009 Posted April 5, 2009 Lambda isn't need: Command: (mapcar 'set '(v1 v2 v3) '(1 17.2 "Lee Mac")) (1 17.2 "Lee Mac") Command: !v1 1 Command: !v2 17.2 Command: !v3 "Lee Mac" Quote
Lee Mac Posted April 5, 2009 Author Posted April 5, 2009 Hey Lee, I think the problem lies with declaring the symbols V1,V2 &V3 as variable names using SETQ. Using the function (setq x y) you are actually pass two arguments; X to create the variable and Y to assign it a value. In this instance I think SET would seem to be more appropiate From the acad support on SET Try the following (defun c:test (/ vlst) (setq vlst '(v1 v2 v3)) (mapcar '(lambda (x y) (set x y)) vlst '(1 2 3)) (princ)) Hope this is of some help, Jammie Lambda isn't need: Command: (mapcar 'set '(v1 v2 v3) '(1 17.2 "Lee Mac")) (1 17.2 "Lee Mac") Command: !v1 1 Command: !v2 17.2 Command: !v3 "Lee Mac" Ahhh! Many thanks guys for your time and patience I have never used "set" and so it didn't come to mind when thinking of which functions to use. Thank you both for such clear explanations Cheers Lee Quote
Lee Mac Posted April 5, 2009 Author Posted April 5, 2009 Thanks guys, put the knowledge to good use ;; ============ Num.lsp =============== ;; ;; FUNCTION: ;; Will sequentially place numerical ;; text upon mouse click, with optional ;; prefix and suffix. ;; ;; SYNTAX: num ;; ;; AUTHOR: ;; Copyright (c) 2009, Lee McDonnell ;; (Contact Lee Mac, CADTutor.net) ;; ;; PLATFORMS: ;; No Restrictions, ;; only tested in ACAD 2004. ;; ;; VERSION: ;; 1.0 ~ 05.04.2009 ;; ;; ==================================== (defun c:num (/ vlst ovar dVars tmpVars pt) (setq vlst '("OSMODE" "CLAYER") ovar (mapcar 'getvar vlst)) (setvar "OSMODE" 0) (or (tblsearch "LAYER" "NumText") (vla-put-color (vla-add (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) "NumText") acYellow)) [color=Red][b](setq dVars '(sNum inNum Pref Suff)) (mapcar '(lambda (x y) (or (boundp x) (set x y))) dVars '(1 1 "" ""))[/b][/color] (setq tmpVars (list (getreal (strcat "\nSpecify Starting Number <" (rtos sNum 2 2) ">: ")) (getreal (strcat "\nSpecify Increment <" (rtos inNum 2 2) ">: ")) (getstring (strcat "\nSpecify Prefix <" (if (eq "" Pref) "-None-" Pref) ">: ")) (getstring (strcat "\nSpecify Suffix <" (if (eq "" Suff) "-None-" Suff) ">: ")))) [b][color=Red](mapcar '(lambda (x y) (or (or (not x) (eq "" x)) (set y x))) tmpVars dVars)[/color][/b] (while (setq pt (getpoint "\nClick for Text... ")) (Make_Text pt (strcat Pref (rtos sNum 2 2) Suff)) (setq sNum (+ sNum inNum))) (mapcar 'setvar vlst ovar) (princ)) (defun Make_Text (txt_pt txt_val) (entmake (list '(0 . "TEXT") '(8 . "NumText") (cons 10 txt_pt) (cons 40 (max 2.5 (getvar "TEXTSIZE"))) (cons 1 txt_val) '(50 . 0.0) (cons 7 (getvar "TEXTSTYLE")) '(71 . 0) '(72 . 1) '(73 . 2) (cons 11 txt_pt)))) Quote
jammie Posted April 11, 2009 Posted April 11, 2009 Your welcome Lee, Glad to be of help. I learned a bit more about Set and Setq myself from this post Nice work with the routine as well -Jammie Quote
Lee Mac Posted April 11, 2009 Author Posted April 11, 2009 Your welcome Lee, Glad to be of help. I learned a bit more about Set and Setq myself from this post Nice work with the routine as well -Jammie Cheers Jammie Quote
StevJ Posted April 11, 2009 Posted April 11, 2009 That's a really nice program, Lee, but in order for a leading zero to be retained, I have to make it the prefix, or include it as part of the prefix. Is there a way around this characteristic of the program? Prefix VB and number 0801 becomes VB801 unless I make the prefix VB0. I ask because you have made the program easy to modify, so that if I don't need a prefix or suffix, those lines can be commented out, and they will not be a bother. But until 2010, I could sure use a leading zero. Thanks, Steve Quote
Lee Mac Posted April 11, 2009 Author Posted April 11, 2009 Well, this is a quick fix, but not ideal ;; ============ Num.lsp =============== ;; ;; FUNCTION: ;; Will sequentially place numerical ;; text upon mouse click, with optional ;; prefix and suffix. ;; ;; SYNTAX: num ;; ;; AUTHOR: ;; Copyright (c) 2009, Lee McDonnell ;; (Contact Lee Mac, CADTutor.net) ;; ;; PLATFORMS: ;; No Restrictions, ;; only tested in ACAD 2004. ;; ;; VERSION: ;; 1.0 ~ 05.04.2009 ;; ;; ==================================== (defun c:num (/ vlst ovar dVars tmpVars pt) (vl-load-com) (setq Zer0 T) ; Leading Zero (T or nil) (setq vlst '("OSMODE" "CLAYER") ovar (mapcar 'getvar vlst)) (setvar "OSMODE" 0) (or (tblsearch "LAYER" "NumText") (vla-put-color (vla-add (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) "NumText") acYellow)) (setq dVars '(sNum inNum Pref Suff)) (mapcar '(lambda (x y) (or (boundp x) (set x y))) dVars '(1 1 "" "")) (setq tmpVars (list (getreal (strcat "\nSpecify Starting Number <" (rtos sNum 2 2) ">: ")) (getreal (strcat "\nSpecify Increment <" (rtos inNum 2 2) ">: ")) (getstring (strcat "\nSpecify Prefix <" (if (eq "" Pref) "-None-" Pref) ">: ")) (getstring (strcat "\nSpecify Suffix <" (if (eq "" Suff) "-None-" Suff) ">: ")))) (mapcar '(lambda (x y) (or (or (not x) (eq "" x)) (set y x))) tmpVars dVars) (while (setq pt (getpoint "\nClick for Text... ")) (Make_Text pt (strcat Pref (if Zer0 "0" "") (rtos sNum 2 2) Suff)) (setq sNum (+ sNum inNum))) (mapcar 'setvar vlst ovar) (princ)) (defun Make_Text (txt_pt txt_val) (entmake (list '(0 . "TEXT") '(8 . "NumText") (cons 10 txt_pt) (cons 40 (max 2.5 (getvar "TEXTSIZE"))) (cons 1 txt_val) '(50 . 0.0) (cons 7 (getvar "TEXTSTYLE")) '(71 . 0) '(72 . 1) '(73 . 2) (cons 11 txt_pt)))) Quote
Lee Mac Posted April 12, 2009 Author Posted April 12, 2009 That did it. Thanks, Lee. Steve No Problem Steve - I am currently working on an updated version of the above - when complete, I shall be sure to post it Lee Quote
